Question about Westinghouse LTV-32w3 HD Television
Picture quality I have had a Westinghouse LTV-32w3 HD TV for about a year and a half and within the past month or so it has developed a picture quality problem. The problem is it produces green sparklies throughout the screen but are particularly noticeable in darker parts of the picture. They appear and disappear randomly like they are blinking off and on. There are also blotching of colors on faces on the screen. Hope this info will help to diagnose the problem. Thanks N. Unck
  • 4 more comments
  • Anonymous Jul 12, 2008
    I have almost the same problem, except the distortion is red. When I watch a show or movie that is really dark, the whole screen is pretty much blood red. Eventually turns off after about half an hour, almost as if the unit has to warm up or something. Unplugged it, for about 30 minutes to reset it, nothing. Moved the cable/router unit and put the cable straight from the wall to the TV, nothing. No one from Westinghouse has gotten back to me.
  • Anonymous Jul 30, 2008
    i get the green and the red, i'll try the wireless router move
  • jnBlue Nov 05, 2008
    Ours has the exact same problem, the blotchy distortion is red. The defined images are covered by a red glow, not just an overall indistinguishable red screen. Sometimes stops after awhile as if the unit had to warm up more, but then returns. Sometimes helps to reboot it, sometimes not. No cable/router unit nearby, and sometimes it doesn't do it at all for hours; so it seems to be an actual internal processing issue. Would be glad to take or send it to be repaired or pay reasonably for replacement/upgrade to newer design, but no response from emails to Westinghouse at all. IF they had a better service response we'd even replace with another Westinghouse since it had great image quality until it got out of warranty & began to malfunction... Best solution? unfortunately - Avoid Westinghouse products! Any other ideas for those of us stuck with one of these 'you can be sure' turkeys???
  • plutino Jan 16, 2009
    I have exactly the same problem. Colors I have seen so far include red, green, and cyan. Sometimes it becomes so severe that nearly the whole screen becomes red, and then all of a sudden all the disturbing dots disappear and the screen goes back to normal. I'm still looking for a solution, or a new TV
  • mrspaige Mar 10, 2009
    My problem seems to be with the white color. After a while, the white color drops out to an aqua blue color, sometimes pink too. No rhyme or reason to it. Then it goes away, then comes back, etc.
  • Anonymous Apr 20, 2009
    The colors become distorted with pink, red, greens and it looks as if someone has spilled different colors of paint and they all run together. You cannot make out the figures at sometimes.
I had the same problem before. I had my wireless router really close to the tv. I relocated the router, and the problem never came back.
Posted on Jun 19, 2008
Same problem with mine i unplugged it for half hour and plugged it back in it works fine now
Posted on Apr 16, 2009
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
Aug 01, 2011 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Get my PIP to work!!!!!!!
The "Picture in Picture" function will only work with a "digital" source like hdmi or dvi input. It will not work with an s-video or vga input source.
Oct 31, 2009 | Westinghouse W32701 27 in. LCD HDTV
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
Picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
My westinghouse lcd tv ltv-32w3 hd
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Jul 18, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
540 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
