Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony flat screen
I have a Sony flat screen HDTV and it has a constant high pitch noise in the background, very annoying. How do I fix it?
Turn off the tv
Posted on Jun 05, 2008
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
Hello, I own an LG42PCSD,good picture, but, i am
Sometimes the transformer on the Z-Sustain board can vibrate & give off a high pitch noise or hum, or the tranformers on the power supply, I've even known the plasma screen itself to cause a hum. The best remedy is to try & locate exactly the area of the hum to pin point which board is the cause & then replace the board or if it is the screen, then it is more economical to try & put up with the noise rather than replace the screen.
Jan 08, 2010 | LG 42PC5DC 42 in. Plasma HDTV
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Fridge making annoying high pitch noise almost constantly
mine had a recall on the chipboard. fixed the high pitched buzz, but now i can hear the motor running stronger.
Oct 07, 2009 | Fagor 3FCA-68NFX Stainless Steel ...
Sony bravia dlp constant high-pitched sound
Could very well be the color wheel. This unit spins at 7000rpm and the slightest nick in the wheel can make horrible whine noise.
Aug 19, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Humming noise from NCR RealPOS 70
In a word...yes. Except that you said it is coming from the "screen"? Did you mean the screen on the power supply? If so then yes...probably the fan.
Mar 17, 2009 | Computers & Internet
High pitched noise on Polaroid HDTV
It appears like your power supply is not filtering the voltage properly and that is why you are hearing that high pitched noise. If your LCD is less then a year old, you can call Polaroid to have it repair under warranty.
If more then a year old, check the info from this link to replace the capacitors.
Let me know if you need further assistance.
Oct 07, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Plasma TV Background noise
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
May 28, 2008 | HP PL5000N 50 in. HDTV Plasma Television
High pitch noise...
replacement of the color wheel is an option.. as a technician i dont find replacement all that difficult. finding one too replace it with is the most problem...
May 19, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sound problem
sounds like a fan issue that would be myfirst guess
Mar 21, 2007 | LG RZ-37LZ30 37 in. LCD Television
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
298 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
