Question about RCA D52W19 52" Rear Projection Television
Convergence problem I have a rca D52W19 that I need to replace the convergence boards my local repair guy gave me an estimate of 390.00 can you help me find the parts and instructions. Thanks
  • RCA Master
  • 5,138 Answers
When you go into menu do you see covergence in setup,if not then it is not your convergence boards,next to your fiyback transfomer this is the power supply board there is 3 small fuses the one in the middle opens FL231 they look like small brown square caps 0.4 amps.
Posted on Jun 06, 2008
  • RCA Master
  • 8,617 Answers
The following link will have the parts you need and instructions on how to install them. Just leave an email with your model number and what youre needing.
http://servicemanuals.vstore.ca/
Picture on screen goes out of focus
If attached photos look like what it does it is a convergence problem common in the RCA sets.
Frankly I do not like these sets and if You GOOGLE the model number with "convergence" or "problems" you will a ton of them with that problem.
The real trouble is most sets (even the early RCA) have the convergence circuit almost 100% on one board and use one or two chips for this.
This set has it spread across two or three boards and all the parts are RCA only.
Considering how poorly made that set is I would not if someone gave me one take it or repair it.
The photos will tell you if it is your problem--no two sets look exactly the same but you will know from the pictures if it is your trouble.
Mar 19, 2012 | RCA D52W19 52" Rear Projection Television
Rca d52w19 rear projection changed flyback and cp150 cap. fuse fl231 is good . have bowed screen and 3d effect. convergence shows in menu but cannot adjust at all.
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from www.tvrepairworld.com
Mar 31, 2011 | RCA D52W19 52" Rear Projection Television
How do I fix this problem with the color green misaligned? I checked the convergence board and power board to see if any fuses were burnt up but nothing. It only does it when certain things are on tv. For...
Did you try to do a hard reset to bring up your convergence option. Its been awhile but I think you have to unplug your unit for 24 hours . Then your convergence option will come back up.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
Convergence nightmare
the convergence board wuld not solve the problem, you need the convergence power supply board for the ITC222 you can get one at the following link with free instructions.
Sep 24, 2008 | RCA R52WH73 Projection Television
RCA Model D52w19
One thing that comes to mind is the two main connectors on the power/deflection board. They have ribbon cable in them. If they are white in color. One of them plus the one on the convergence board that is the same size, needs to be replaced. If they are black they are good. Part number is 258686. If your serial number is between G13XXXXXX and G26XXXXXX this is a very good posibility.
Aug 04, 2008 | RCA HD52W58 52" TV
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
Convergence issue at screen edge
Sounds like a technician that failed to do the convergence alignment that should be checked after any repair. No nudging needed, maybe just nudge the technician who fixed it.
Feb 15, 2007 | RCA D52W19 52" Rear Projection Television
D52W19 convergence problem
Since this is an intermittent problem, I would first check the convergence board for cracked solder connections or other loose connectors (or leaky capacitors and diodes). If you still cannot find the problem, you will most likely have to replace the convergence board assembly p/n 264103. It can be quite difficult to re-converge if you do this unless you swap the two eeprom IC's on the original board to the new board IK210 and IK211 then Go Into The Service Menu Geometry And Set V Slope And H Position, Save, Then Back Out To the Customer Menu And Run AutoConvergence.
Dec 22, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
173 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
