Question about HP PSC 1510 All-In-One InkJet Printer
1510 Printer absolutely unpredictable!!!! Jams, says it is empty, snarls the paper, it is getting worse. Should I get it repaired or buy a new one????
    Problem Solver:
  • 12 Answers
If its a year old you should go for a new one as this is a common problem with printer which are one year old.
Posted on Jun 05, 2008
Pls help me how to fix paper jam?
I've got a Brother 2070-N mo no-laser,, a LexMark X5360, a Brother MFC 495-CFW, and they have all had this problem. The laser printer and LexMark have been in the closet, too new to toss, but absolutely NO paper jams. Since it can be maddening to be told over and over "be sure and look for a paper jam" when you've already done that, and done it, and DONE it, I'll share the other common tips I've seen so you won't have to read them, too:
Paper rollers have rubber grips in various places, and they may also have little wheels called "tractors" that advance the paper, or both at different points in the paper path. They can get loose, or dried out and not very grip-py, or the tractor wheels can get loose or on the wrong settings, etc so they no longer firmly grasp and advance the paper. These will set off the alarm. Cleaning, replacing grips, or even turning rubber grips inside out can help. You'll have to fiddle with the tractors to be sure they are snug against the paper, and roll easily, etc.
Sensors can get dirty, and need cleaning, or go bad and need replacing. If so, it's a very cheap fix, sometimes--call and ask the company what the part number is (according to one repairman on FixYa). Problems with the paper tray can keep the paper from responding to normal traction, as it can when the tray is nearly empty. And everyone says to search for even the tiniest item--not always paper--that has gotten loose or fallen down into the paper path...shake upside down, jiggle, open every openable part and search, etc.
After I finish installing my 3rd new printer, I'll check some of these out. It's pretty clear that taking printers to a repair service is more expensive than replacing--provided you spend an hour researching the cost of supplies for the "inexpensive" replacement you choose. Oh, the games they play with printer ink cartridge fees! Ink for a cheap printer can be double the cost for a pricey one, but the way things are packaged and how replaced when you run out (all 3 colors in one cartridge, or separately? etc.) makes a big difference. Do the math first. I found I was buying many color cartridges becuase my color ink dried up unused and the printer wouldn't print without them--and those were replaced separately since they didn't dry out at equal rates...but buying individually was pricey. It may be worse when I have to buy all 3 together--or not.
It might also be worth keeping a nice all-in-one when the printer part goes bad, and replacing the printer function with a new, super-simple cheap printer (if they exist; most are everything-but-fax), or a good small mono-laser that does nothing but print, no color. That's what I'm going to do next time; for now I have an all-in-one (minus the broken printer function) for every phone in the house, and this new one with a printer. LOL.
Jul 05, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Paper jams
Go To Below official HP Printer Page For Your problem,http://h30434.www3.hp.com/t5/Other-Printing-Questions/Printer-Paper-Jam/td-p/126558
Still having Problem Then follow Us For HP Printer Support
Feb 24, 2014 | HP PSC 1510 All-In-One InkJet Printer
Paper jam! paper begins to feed then goes crooked
Please do all the things that you can do before you consider buying a new printer. You can take your printer into a service repair center or computer repair center in your place. If there is nothing that they can do then you can take an option of buying a new one.
Nov 28, 2009 | Lexmark X4530 InkJet Printer
Paper jams every time I try to print...I remove paper, still jams everytime.
one of the tracks is off, or something inside the printer is bent / loose. you will either have to buy a new printer, send it back to the manufacturer, or find a local PC repair shop that will actually work on printers. your cheapest option is to buy a new printer.
Sep 24, 2009 | HP Photosmart C5280 Printer
HP PSC 1510 ALL IN ONE
salut ROSENEDKER !
demonte entierement ton hp psc 1510 entierement et regarde du cote droit a la station de nettoyage;il ya une petite target qui doit etre cassee du cote haut ou bas . je dis bien cette target se trouve au bout du bloc des rouleau avance papier avec un ressort de rapel accrocher dessus . Merci et bonne chance
May 26, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All in One paper jams and wil not feed properly.
www.hp.com/support the people at HP have been very helpful to me try this and see what you get
biigg53566@gmail.com
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-in-One Printer check paper light on/ no paper jams / filled with paper
go to add/remove printers and remove it... remember to unplug your printer before that...
connect your printer while the computer is ON (PSC series is a plug and play printer)... the computer will detect new hardware and reinstall it on its own... it might ask for the CD you got with printer... so keep it handy.
Nov 12, 2008 | Office Equipment & Supplies
HP 1510 - Photo Paper Jams
Hi, try using HP brand photo paper, HP makes their special photo printers and special photo paper for them.
The surface of the back of the HP's paper is rough, like sandpaper to avoid the paper being jammed in the cheap loading mechanism of their actual printers.
Oct 11, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
