My pc has a samsung HD161HJ hard drive as a second hard drive but now it wont reconise it in my computer and when it does it wont let me save anything on it
  • nsindian
    nsindian May 11, 2010
    When it does recognize it, check to see how it is formatted by right-clicking drive and selecting properties. it should say FAT32 or NTFS.
  • 55 Answers
It sounds like your drive is going bad. If you have a back up of your data, install a new drive and restore your data.
If your system can not recognize your drive, it means it can't read sector 0 from your drive. This sector contains crucial initial information about your drive, and it wouldn't work without it.
Posted on Jun 05, 2008
I have a Barracuda ST3160813AS drive in my pc. I want to add a Samsun HD161hj as slave but have had no luck
you will need to set the jumpers on the second hard drive to slave. Unless they are sata drives then you should have no problem.
Nov 10, 2012 | E-Machines eMachines Refurbished EMA...
HD NOT RECONISED BY COMPUTER
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 23, 2012 | Computers & Internet
I cant save anything on the 1T external hard drive. I am running windows 7. The computer reconizes it but wont save
The Hard Drive must be Write protected. There might be a Toggle switch around External Drive for Write Protection. Or can you save files to any other USB Drive (Pen Drive) ?
May 18, 2011 | Samsung G3 Station 1TB USB 2.0 Black...
Dear Sir/Madam i want my samsung hdd warranty chek M/N: HD161HJ S/N : SOV3J9BPB69499 TRICK TRICK SOUND HEARING IN HDD
The spinning mechanism is failing. If you can access it from the computer, back up your data as soon as possible. Then, take it to the vendor to claim warranty replacement.
Feb 26, 2011 | Samsung Spinpoint M7 HM161HI 160GB 8MB...
Samsung 310. Wont load up not even in safe mode, after a few seconds the screen goes black and the cursor appears and thats it. Relatively new computer. My main concern is losing the photos I have saved......
send it back to the manufacturers, they will take out the hard drive and repair the computer, the hard drive with all of your photo's will be put back in and your problem will be fixed!
Jan 27, 2010 | Samsung Q310-34P Mobile Notebook
Samsung hd161hj problem
If his hard drive responds in safe mode then the bios is detecting his hard drive right and nothing you can do will make it any different. It doesn't matter what the bios is set like on his computer and how it installed.
The problem is you have two different machines. When windows installed on his computer it detected his motherboard chipset, the motherboard add on, the ide and psi ports and installed the drivers for his board. Now you're installing it on your computer with a different motherboard, different chipset, ports etc.. Windows doesn't autodetect and install motherboard drivers like it does other peripherls. Unless the motherboards are amost identical, when you put a hard drive with Windows installed on another system into a different system Windows will 99% of the time fail to run. Most the time you'll get a blue screen of death with a driver name on it that failed. You can configure that drive as a slave and put both drives in and boot off yours and see his.
Dec 06, 2009 | E-Machines eMachines Refurbished EMA...
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
Have maxtor bought today my pc wont reconise it
The drive needs to be installed and recognised and then formatted
go to start/control panel,add new hardware and let windows search for the hard drive.
if it cannot find it then opt for a manual installation and follow the instructions
Dec 09, 2008 | Computers & Internet
Dropped hdd beeps wont be reconised by computer
What kind of beep is that? Anything similar to these sounds: http://datacent.com/hard_drive_sounds.php ?
Most likely the spindle got stuck. That's really bad.
Oct 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
