Question about Akai LCT2721AD 27 in. LCD Television
Tv got a mind of it own
I can't program the any remotes to work on this tv also V-chip is locked and i can't get the password to work
    Scholar:
  • 42 Answers
To unlock the V-chip on any tv you must contact the Manufacture of the tv by their 1800 number and if this tv has a built in Dvd player, universal remotes will not code to the tv due to it being a 2 in 1 model. Most Direct tv services also cant program their remotes to these tvs due to the same nature.
Give Akai a call on their 1800- and see if they can go over their process of how to remove the v-chip lock. And get a estimate on a replacement remote.
Posted on Sep 11, 2008
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
passcode. This is done by pressing the
TV control at the same time, when your
password is requested. This process
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Jan 21, 2010 | Durabrand DU1301 TV
Tip
Bypass Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Reset Mitsubishi HDTV VChip Password
I hope that helps.
Forgot the password to tv
Good Day,
Bypassing the V-ChipLock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
When changing or deleting your passcode, you must use the remote control included with this TV. You cannot use any Mitsubishi remote control from another component or a "universal" remote.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62327 62" Rear Projection...
My 20 inch tv is locked out of mature programs how do i fix it i go to the menu program but it requires a password to enter the v chip or acess
If you try these solutions hopefully they will work for you...
The V-CHIP is bypassed holding down the VOLUME DOWN on the TV set and the ZERO key on the REMOTE control. This will alow you to go to the V-CHIP menu (TV MODE) and set a new password.
To bypass/override the V-CHIP password see the see explanation above, and to clear the forgotten parental control password (DVD mode) you need to hold down the VOLUME DOWN on the TV set and the FOUR key on the REMOTE until the message “Initialize5 Complete” appears on the TV screen. After that, you can set the new parental password.
Best Wishes,
Karlos
Jun 28, 2009 | Televison & Video
Password
If I knew the model number I could tell you where to find your manual. I'll give you a link to the website that can help find your manual at the end. If you haven't already tried here is another method that may work.
US V-Chip TV Rating Limit
The V-Chip TV Rating Limit lets you decide which TV programs can and cannot
be viewed.
To set TV programming limits:
1. Choose Parental Control from the MAIN MENU. If Parental Controls have
previously been locked, you must enter your password.
2. Highlight and select US V-Chip. Then select V-Chip TV Rating.
3. Once you get to the V-Chip TV rating limit screen, use the arrow buttons
and OK on your remote to change the status of a TV program rating or
content theme from View to Block.
4. For TV rating limits to take effect, lock Parental Controls by accessing the
Lock parental controls menu.
The following sections give you more details about how to change the status of
TV program limits.
Note: If you forget your password, follow step one above to get to the
password entry screen. Then press the VOL+ and CH+ buttons on the TV's
front panel at the same time for at least 8 seconds. You will receive an
on-screen message that Parental Controls have been unlocked once y
Or try this link to help find your particular model number and download your manual. http://support.rca.com/index.html
Jan 03, 2008 | RCA TruFlat 27F520T 27" TV
Akai LCT2721AD 27 in. LCD Television Logo
108 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
