Question about Sanyo PLC-XU58 Multimedia Projector
Sanyo PLC-XU58 projector completly dead
Have a Sanyo PLC-XU58 projector was working one day not the next its completly dead when plug in no sounds no led lights absolutly nothing - have tried a different power cable and there is nothing obviously wrong with it bulb is fine and it hasn't been dropped bash or overheated inbetween working and not working - any idea?
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Posted on Oct 12, 2008
I have a Sanyo PLC XE20 which powers down after a few seconds with a bulb error I purchased a new bulb but the problem persists. What next?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 08, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Hi i have sanyo xu58 , i cant seem to find a bulb , Will there be any other bulbs that will fit mine?
Hi I have recently purchased Sanyo projector bulbs from avpartsmaster, google them they are based in Bracknell Berks, failing that you can pick them up brand new on ebay.
Good luck.
Ian.
Dec 20, 2010 | Sanyo PLC-XU58 Multimedia Projector
QUERO COMPRAR A LAMPADA PARA O PROJ. SANYO PLC XU 100 BARROSO 86-9981-2684
USD140,the Original lamp
have a nice day!
Aug 17, 2010 | Sanyo Projector Lamp for PLC-XU100,...
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Flashing red Power light, but unit won't start
I had a similar problem, but with no lcd lights showing and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure. Perhaps you will have to check the ballast for problems
Jul 28, 2008 | Sanyo PLC-XU58 Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo PLC-XU58 Multimedia Projector Logo
217 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
