HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Posted on Oct 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We purchased a new computer and it runs Windows 7 while our old one ran windows xp. I can not get the printer software to download what do I need to do to make my printer compatible with windows 7?
Anonymous
Level 2:
Genius:
  • HP Expert 1,325 Answers
  • Posted on Oct 20, 2010
Anonymous
HP Expert
Level 2:
Genius:
Answers
1325
Questions
Helped
344265
Points
292
1helpful
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
I just upgraded from an old dell (windows XP) to a new machine running windows 7. I have an hp scanjet 4570c scanner that I want to use. It ran fine on XP, including the HP director software and the HP...
if you still have the installation disc for the printer use it when adding a printer to the win 7 os
or go to hp download site and download the drivers for the printer
or may be go to the printer properties tab , click on compatibility and tick the box and high light win7 os and apply
1helpful
2answers
I purchased a new printer (running Windows 7). I transferred my Lexmark all in one printer X1100 from my old computer (running XP). When I insert the installation disks, I cannot get past the language...
hello
you need the driver of your printer which is support the windows xp, the driver you have is only for windows 7 you need driver for windows xp. you can search it thru the net.
just leave comments i'll get back to you
thanks
4helpful
3answers
Have a new computer with windows 7. my old husqvarna viking #1 sewing/embroidery machine software is downloaded, but unusable. Viking says to buy new software costing at minimum $500.00 The message I...
You will have to maintain an XP computer or buy new software there is no fix for your problem.It's the electronic age the old software was written for the XP operating system.When MS changed the operating system Husqvarna Viking had to design new software it's that simple.Don't blame the manufacturer Microsoft made the changes that created the problem. www.sewvac.com
2helpful
2answers
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
2helpful
3answers
Lost product key for xp professional
search here I recommended to download the software
k24674
Grand Canyon Tech
Grand Canyon Tech
