Question about Video Game Consoles & Games
A scratched cd - Video Game Consoles & Games
    Problem Solver:
  • 15 Answers
Put rubbing alcohol on a tissue or something soft, and slowly wipe the tissue from the inner part of the cd to the outside repeatedly all around the disc. Wipe the disc with another DRY soft object after to remove excess alcohol.
Other things besides alcohol that may work include:
1.Pyroxide
2.*Possibly* toothpaste, my friend told me this may work, but unknown
3. You can buy disc cleaning solutions at some stores that work well
Posted on Jun 06, 2008
The disc is scratches
If the scratches are only fine then you can polish out these scratches.
You need to purchase a CD scratch polishing kit from the computer shop or from the Internet.
Follow the instruction on the CD polishing kit.
Mar 30, 2011 | Computers & Internet
Tip
HOW to Recover Data from Scratched CD's
HOW to Recover Data from Scratched CDs
All CD or DVD are always get some scratches when you use or even if your carefully using it,there's time that accidentally make some scratch in it.this tip is a painless techniques on how to create a full working CD from the scratched one. I have personally tested this and had fixed a CD that would not read data at all. This tip works best with small unreadable scratches, as some hard scratches are too deep and loose the data permanently.
Requirements:
1:Alcohol 120% software [or similar]
2:Cooking oil
3:Small piece of cotton
4:Dry cleaner paper
Follow this simple steps to fix a scratched CD for repair purposes:
In step one you must do some preparation work on the CD. Begin by wetting the cotton with water. Begin to clean the CD in a vertical motion; three firm wipes shall be sufficient. Dry the CD with the dry cleaner paper.
Using another piece of cotton, apply oil to the CD surface. Be sure to do this with caution and not overuse oil. After a through cleaning, dry carefully. Particles from the oil will stay on the micro surface of the scratch. It appears that the oil helps the laser of the CD/DVD driver
to read the surface again.
After downloading and installing Alcohol 120% software, run the program and select to create an ISO - image making wizard. Attempt to read the CD drive and test if the program can read the Alcohol 120% software is recommended for this, as it is known to recover data more efficiently than other ISO software.
If a successful read is obtained, I recommended creating a new CD immediately. Copy all the data from the CD to the hard drive or create an ISO of the CD for immediate use. With a favorite burning utility, burn the ISO or data onto a new CD.
on Sep 09, 2011 | Audio Players & Recorders
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    How do u apply the fellowes cd scratch remover in bottle?
    from the center out...or outside to the center. do not do circles that just makes the laser follow the scratch and report the error. ..
    Dec 05, 2009 | Fellowes FEL99763 CD/DVD Scratch Repair...
    Sound output
    hmmmmm is the CD scratched? if you transfer it to the computer, then to the MP3 and the CD is scratched then it comes out all wonky but if the CD is scratched then just ignore it, and heres how you can tell that its the CD not the MP3 ;
    some songs are not scratched if all were scratched then the MP3 doesn't work properly.
    and thats it
    Jul 17, 2008 | SanDisk Sansa e270 MP3 Player
    Scratched disk
    hi, this is a common problem with all video games consoles that take cd and the same for music cds.
    Most people throw them out when they get scratced and start jumping or in your case wont load the game.
    The good news is you can buy a cd polishing kit which polishes the scratches out of the disk.
    How it works is you place the cd into a like similar to a cd box but it has three sanding wheels then when you put the disk in you then turn a small handle and the three polishing pads spin round and polish the scratches out of the cd getting the disk to work again.
    The problem is finding some where that sells them i know Maplin stock them and sells them but if you have trouble finding anywhere that sells them then the best thing to do is type in in your browser "cd scratch remover" then this will list a load of sites that sell this product.
    Its not expensive to buy and its well worth getting one as you can use it loads of times so if in the future you have more problems with scratches then its worth getting one.
    Hope this is the help you was looking for i know they work as i use one myself for my ps2 and music cds that get scratched.
    Let me know how you get on or if you have any questions.
    On any cd the bottom part that the laser reads doesnt have the information and the data on it it is burned into the top part so as you look at a cd and where the writing is on top of the cd if this is scratched and you can see through the disk then it cant be repaired but if its the bottom part that the laser reads from then removing the scratches will solve your problem.
    The scratches cause the laser to miss that bit of data thats under the scratch so polishing these out will be the same as having a new cd.
    May 28, 2008 | Video Game Consoles & Games
    PS2 GTA: San Andreas Disk Problems
    this shows that your cd is already damaged, the scratches might have hit the critical part. you said that some other cd's of yours have also scratches these are presumably minor scratches. its better if you purchase anew one. a damaged cd with deep scratches can damage the lense of your cd rom if you continously use this it would soon permanently damaged the lens
    Dec 02, 2007 | Video Game Consoles & Games
    Need Help with Restore CD's
    I suggest that you replace that optical drive and down load the restore disk from the manufacturers' website.
    May 21, 2007 | E-Machines W4682 PC Desktop
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
