i have a powerpoint IDW12 since nov. 07 and today the 5th june 08 i put it on and it will not start, have in salts and rinse aid, no flashing lights, red light on the right hand side under (!) this sign????????
Can u help me?
regards
andrea.
Did you check the fuse
May i know the model and the make of the product in details so that it can help me resolving the issue in a more prompt manner
If your
dishwasher has a digital readout and you see an error code, it may
indicate a problem with the unit. If this happens, look up the error
code in your owner's manual to find out what the problem is.
If it doesn't work at all
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Is
there power getting to the dishwasher? This can be difficult to test,
because dishwashers are usually wired directly to an electrical
circuit, rather than plugged into the wall. But at least check for a
blown fuse or a tripped circuit breaker.
Door switch
The
door switch is important because, if it's defective, the dishwasher
won't work at all. To reach it, you need to remove the control panel
cover, or sometimes the interior liner of the door. If it's defective,
you need to completely replace it.
Wiring
Often
the main wiring connection from the house, at the dishwasher, burns and
breaks the connection. If that's the problem, the wires must be
repaired/replaced as necessary. If that's not the problem, check the
wiring to the door switch, the wiring between the door and the lower
part of the dishwasher, and the wiring to the timer. Repair any broken,
burned, brittle, or defective wiring, using the proper appliance-grade
wire and connectors.
Although
it's uncommon, the timer or the selector switch may be defective. If
so, you need to replace the defective part, because neither of these
can be repaired.
