Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Changing ics i have the ics,ican see where they go.is there any steps i need to know about how to change them without serious injury to the set or myself.any help would be great. thanks in advance, donniepadre@yahoo.com
  • 3,037 Answers
Make sure the tv is totally discharged, This should be done after being unplugged for 8 hours or you can physically discharge the capacitors.
As long as you know what to do to solder them back on, you shouldn't have anything else to worry about. If you have any questions, let me know otherwise a quick search online should give you complete instructions of how to put them on or you can ask me.
Posted on Jun 05, 2008
Hannspree tv
It sounds that the main system control memory IC is faulty. This is a common trouble to all TVs, irrespective of brand.
It is a very small IC, will look like this, and can be located very near to main system control IC. Won't cost more too. Replace it.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Televison & Video
How to convert sanyo dvr DSR300N(NTSC) to DSR300P(PAL)?
You have to buy one NTSC to PAL signal converter for this, and connect it in beween your tV and DVR.
Apr 21, 2012 | Sanyo DVR-120
How do you change the battery on an archos 7 320gb
The ARCHOS 7 has a removable battery. You can purchase extra batteries fromwww.archos.com.Caution: if the battery is incorrectly replaced or short-circuited, this could resultin damage to the product and/or serious injuries to the user. Replace onlywith an original Archos battery.To replace the battery, follow these steps:
Jan 24, 2012 | INOi Audio Players & Recorders
I was using Nokia 2600 but the screen has gone. I want to get phone numbers from the phones memory to my SIM card. Please help in detail. I know how to begin (menu-2 copy-7 ...) but I don't know the...
first,It that the display IC has gone. It needs a replacement. Please take the phone to Nokia Care and get the IC replaced.you can do easily if the LCD of your phone will change..
Sep 02, 2011 | Nokia 2600 Classic Cell Phone
I need to relight my pilot but don't know how to keep it on
Do not try to manually light the pilot on this model. Serious injury could occur. It is probably a bad igniter. Most HVAC techs carry these on their trucks. Rural hardware stores sometimes carry these as well. Good luck. This would be a good time to change the filter too.
Dec 07, 2010 | Goodman GMS90703BXA Heater
Does anyone know how to change out the A/C compressor to a 1996 cierra?
This job requires special tools and special training. If you lack either, you risk SERIOUS personal injury. Injury comes VERY EASILY!
You need to address oil levels, proper and legal refrigerant recovery, system evacuation, and recharge.
You were planning to also replace the receiver/dryer, correct? It also needs the oil in it measured and incorporated into the amount of oil (in %) that would need to be added. FAILURE to address these and other issues will guarantee premature system failure and likely compressor damage.
Take this job to a qualified shop.
Sorry
Sep 05, 2010 | 1995 Oldsmobile Cutlass Ciera
How do i open a battery and change the battery cells
Here is a site that shows you step by step. http://www.electronics-lab.com/articles/Li_Ion_reconstruct/index_1.html However Special precautions must be taken to avoid Li-Ion battery fire up or explosion that can cause serious injuries. This is because Lithium when comes in contact with water or air's moisture burns violently. Never try to extinguish such a fire with water! but only with suitable extinguisher.
Jan 28, 2010 | Dell Latitude X1 Notebook
I have a Mitsubishi ws-55711 I push the power button and the light goes on for a second and goes out. I did the diagnostic check and it shows 2 blinks then 2 blinks. Do you know if this is the fuses and if...
2,2 is the error code for short protection.
The most common reason for this is one of the 2 pico fuses that protect the convergence circuit is blown. Changing the fuses will not help! They are green in color and soldered into the middle circuit board and are F9a04 and F9a05----look like resistors but are 5 amp fuses.
99% chance if one or both are blown---you have to have someone change the STK-393-110 convergence IC that this set uses----the IC can be purchased on Ebay for under 14 dollars and the same seller sells the pico fuses 5 @ 2.95.
The best thing to do here if you or someone you know is able is to unplug the set and look for the fuses---middle board towards the back---there are 5 of them and the two closest to the back of the row are for the convergence IC----If someone checks them (like testing any other fuse) you will know--if either or both is blown--the convergence IC got them.
I have start to finish, step by step instructions and photos of the fuses etc----If you or someone you know can solder and is handy--you may be able to do the repair yourself.
If not, shops usually charge 300-400 for this kind of repair in this set.
LET ME KNOW IF YOU NEED ANY ADVICE or help.
Regards, SD TECH
Oct 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tire change
Refer to the instructions in your owner's manual or on the cover for the jack/tool kit that came with your vehicle.
Follow the instructions exactly, as failure to do so may cause serious personal injury or even death.
Sep 26, 2009 | 2005 Audi A4
MOBILE REPAIR
try another sim in this handset,, Have u changed teh slot of ur phone.. if not pliz do that.
Sep 20, 2007 | Nokia Handsfree For 6020, 6101, 6102...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
