go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
http://www.russell-hobbs.com/parts.shtml
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
You can access it from the side where the lever is, pull out the knob, remove the edge panel, remove the plastic cover and you will get to the lever and the electromagnet. Most likely the contacts have become dirty clean them up and also remove all bread crumbs from there
