Question about LG LFD790 System
Microphone sound not working
I am trying to attach a univeral mic to my LG tv & sound system. i can only seem to get it to work in 'mobile' on the sound system and tv, however then i cannot hear the television sound. my goal is to hear to mic AND tv sound...karaoke. of course.
help!
You cant do it
Posted on Sep 29, 2008
Trying to determine the cause of intermittent signal from microphone on a vx 4600 radio
Yes, short or lack of a good ground. It could also be the cord attached to the mic. The mic itself should provide the needed feedback to the radio that a mic is plugged in. Do you have anything connected to the accessory jack in the back of the radio? That can cause the same issue.
Apr 07, 2013 | Vertex Standard VX-4600-G7-45 PKG-1 UHF...
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
The microphone jack of my Dell Inspiron 1100 seems to be malfunctioned. When I plug in a microphone, the other side does not hear anything. I tried several different microphones and none of them worked....
Check if the correct recoding device is selected on sound properties, and verify if mic is mute.Test mic using the sound recording program.
Try to uninstall and reinstall the sound driver.
Perform diagnostic on the audio using the drivers and utility disc. if mic is not working on the diagnostic tool then need to replace the sound card.
Mar 12, 2010 | Dell Inspiron 1100 Notebook
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
My micriphone attached to headphone seems not to work.
First, make certain that the mic is really broken, by testing it in another application or devise. Sometimes you cannot hear your own voice unless you are in recording mode! If the mic is found to be working, then try to reconfigure the software, or the Yahoo connection. Good Luck!
Dec 06, 2008 | ASUS Computers & Internet
Microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Jan 27, 2008 | Nintendo DS Console
Samson CO2 Pencil microphones
The CO2 is a condenser mic (also called capacitor mic), and as such, requires phantom power to operate. Ensure that your system is providing phantom power to the microphone, usually accomplished by flipping a switch near your mic input on your sound board.
Dec 19, 2007 | Samson CO2 Professional Microphone
M-udio usb microphone
You should be able to plug your headphones into your computer and get sound that way, assuming your USB mic is plugged in. If the mic is a USB - direct mic (that is, if it is a microphone with a USB cable directly attached), you will only be able to use it with your PC or laptop. If the device is a mic pre-amp (with an XLR or 1/4" connector that your mic PLUGS INTO), then you should be able to use your microphone with any device that will accept that connection type.
Nov 15, 2007 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Sound Input problems
What you have to do is go to your speaker volume icon in the taskbar, right click and go to open volume control and click mute microphone. If mic does not show click Advanced. This dissables the onboard mic but allows the use of your external microphone, rectifying the tinny sound.
Feb 27, 2007 | Acer Ferrari 4000 Notebook
LG LFD790 System Logo
415 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
