Memory I bought a kingston 2 gig memory stick for my computer but when i put it in my computer just beeped.
  • Tuckaway Jun 05, 2008
    Dell Dimension E510 2X1Gb PNY
  • 55 Answers
Unfortunately, you didn't specify what memory or what motherboard you are referring to. If it is DDR or DDR2 memory there are low and high density, buffered and unbuffered, dual and single channel memory modules. You need to refer to documentation on your motherboard to choose correct memory.
Posted on Jun 05, 2008
    Problem Solver:
  • 12 Answers
You must try reseating the memory as the beep code suggest that the memory are not there or not plugged in properly.
check if you are using the right memory card. If not u need to change them.
Hello sir i have kingston 32gb Ccore ccm3110 pendrive it can copy any thing but after copying to my pc the first video file can play ony 14.2 min and others will not open at all solve my problem please
May be your pendrive has corrupted the files or may be your pendrive has some viruses.
I suggest u not to use so much memory on pendrives as sometime pendrive automatically corrupt your data.Use small memory of pendrive.If u want to use big memory it's better u use hard drives
Jan 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I would like to add a memory card reader to my Inspiron B120 that is flush mount so I can just leave it in all the time to read my SD and Sony memory sticks. What would be best?
Hello and thank you for using Fixya.
Your brand of computer calls for DDR2 PC2-4200. This is the "type" you would need to purchase. I would recommend searching eBay for an inexpensive on. The memory sticks come in 1 gig. I would recommedn purchasing 2 sticks of RAM which would eqaul to 2 gigs total.
If you already have a 1 gig stick of RAM, then you would just need to purchase 1 more stick.
As forthe best one, any brand of memory would work. I recommedn Kingston brand but that is just my personal favorite as I know there is a warranty on it and the customer support is great.
Ebay Search
Dec 21, 2009 | Dell Inspiron B120 Notebook
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Oct 04, 2009 | EliteGroup ECS PT800CE-A...
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Jan 15, 2008 | ASUS P4PE-X Motherboard
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Sony Clie n760 memory stick not detected when inserted
Do you share this memory stick with other devices? If you pulled out the memorystick before the device(s) were finished closing the connection, the card may be corrupted. Another thing may be because your memory stick may be too large for your handheld to support. if you don't wanty to refund your $ just shrink the memory stick into a gig or less. You have to have a pc with a memory card reader that supports memory stick. just open up my computer> right click the memory stick> Fortmat and select a smaller size to format to.
Jun 25, 2007 | Sony CLIE PEG-N760C Handheld
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
