Question about Microsoft Xbox 360 Console
Xbox360 1 flashing light. error message on startup,graphics
  • 31 Answers
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Posted on Mar 14, 2009
  • 284 Answers
Make sure the connector to the tv is plugged in.
make sure its snugged
and fitting correctly
Posted on Jun 18, 2008
Why are parking lights flashing 5 times at startup
Replaced electronic module ?????? Which electrical module ? Did you have the vehicle check for DTC'S - diagnostic trouble code's ? Not engine OBD2 code's ,but the body control system modules . FEM - front electronic module , REM - rear electronic module plus the instrument cluster ! The main light switch is an input to the istrument cluster . Everything is done by computer , input from main light switch for park lamp activation or headlamps ,running light's etc.. to the instrument cluster . The instrument cluster has a microprocessor inside ,with logic . The I/C will send a message over the SCP serial data communication bus to the other modules ,and the one the message is intended for will read it an turn on the light's or what ever the message tell's it to.
The park light's flash when ? Opening the doors , when starting the vehicle ????? Content theft system function ? do the horns sound too ?
Dec 15, 2017 | 2002 Ford Thunderbird
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Error 53000921
Your video processor has a problem, seems like it is overheating:
graphic glitches on startup blue screen
Also, my computer would blue screen on me when i tried to run a high end graphical game, in this case Guild Wars.
I ran a full length diagnostic on my video card, and over half the tests failed.
I had many errors in the reading and writing of video memory, and failed tests of whether a page was void of colour errors and such.
I wrote down all the error codes and they are as follows:
If you're under warranty, call Dell with the error information and they will replace the video card. If you're out of warranty, you can order a card:
Dell Spare Parts 1-800-449-3355 ext 7269937
Nov 23, 2010 | Dell Inspiron 9400 Notebook
ACDSee 7.0 Device Detector stalls Windows startup
try uninstalling and reinstalling on a diffrent drive.... if youhave one
Mar 04, 2010 | ACDSystems ACD Systems 7.0 Powerpack for...
I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hp pavilion a705w Light flashed in front and back on and off
Try a different monitor with your PC. If it does the same thing then you know the problem is with your PC. Also connect your PC to a different monitor. If it works OK then your monitor is bad. Does it beep at startup? Describe beep codes and someone on this website will decipher them for you. This might help to diagnose the problem.
Jan 12, 2009 | HP Pavilion a705w PC Desktop
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
