Question about Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
We do high volume laser printing normally on HP Laserjets. We had a request from a client to print a job with color logos so we bought a Ricoh Aficio CL3500N. We printed the job from JetLetter 4.710 using pc with Windows 98 with the Ricoh Aficio CL3500N PCL 5c driver. It was a 2-sided letter with an 8" x 8" box with about 24 color logos in it with around 2000 records. When we printed to the Ricoh Aficio CL3500N, it printed fine for around 50 records and then started dropping lines of text and/or graphics. Does anyone know what could cause this?
  • 1,049 Answers
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Posted on Jul 24, 2008
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
Aug 02, 2017 | Brother HL-2130 monochrome laser printer...
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
Printing speed problem
Laserjets have limited amount of ram to keep large docs in memory, you can increase the document or in windows have it spool on your machine first.
Apr 22, 2009 | HP LaserJet M1522n MultiFunction Printer
Attention light, print stops.
either you upgreat memory or print order less than 50 pages at a time.
Mar 14, 2009 | HP LaserJet 1320n Printer
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
Borderless printing brother HL- 4040cn
This model can't suppor boderless printing. check this for details.
Basic Specifications Printer Type Laser/LED - Color Form Factor Desktop Color Yes Print Technology Single-pass electrophotographic laser Resolution Black Maximum Resolution, Plain 2400 x 600 dpi Speed First Page Out, seconds 16 Black Print Speed (Draft) 21 ppm Controller Specifications Processor Speed 300MHz Memory, standard 64MB Memory, maximum 576MB Languages PCL6, BR-Script3 Fonts Supported PCL: 66 scalable fonts, 12 bitmap, 13 bar codes
BR-Script3: 66 scalable fonts Special Features Borderless Printing No Automatic two-sided Printing Yes Direct CD / DVD Printing Support No Paper & Media Handling Paper trays, std. 2 Paper Input Tray1 Capacity, sheets 50 Paper Input Tray2 Capacity, sheets 250 Paper Output Bin Capacity, sheets 150 Recommended monthly volume, pages 35000 Paper Types Plain paper, bond, envelopes, labels Supported Paper Sizes Letter, Legal, Exec, A4, A5, A6, B5, B6; Envelopes: Com 10, DL Connectivity Interface(s) 10/100 Base-TX Ethernet, Hi-Speed USB 2.0, USB Direct Interface, 802.11b/g Wireless, IEEE1284 Parallel Network Ready Yes Security Features Wireless Network Security: WEP, WPA/WPA2-PSK (TKIP/AES), LEAP (CKIP), SecureEasySetup Software Details Utilities Interactive Help, Driver Deployment Wizard Windows OS Compatibility List Windows Vista/XP/XP Professional x64/2000, Windows Server 2003/2003 x64 Mac OS Compatibility List Mac OS X 10.2.4 or greater Front Panel Display Yes Physical Details Width, inches 16.5 Height, inches 12.5 Depth, inches 18.7 Weight, lbs 64.2 Additional Details Additional Details - Time to First Page: Less than 16 sec (black)/17 sec. (color)
- Optional Paper Input: Up to 800-sheet total capacity via 500-sheet paper tray
- Multi-Protocol Support: TCP/IP (ARP, RARP, BOOTP, DHCP, APIPA (Auto IP), WINS, NetBIOS name resolution, DNS Resolver, mDNS, LPR/LPD, Custom Raw Port/Port 9100, SMB Print, IPP, IPPS, FTP Server, SSL/TLS, POP before SMTP, SMTP-AUTH, TELNET, SNMPv1, HTTP/HTTPS server, TFTP client and server, SMTP Client, APOP, LLTD responder), Apple’s Simple Network Configuration for OS X 10.2.4 or greater, TCP/IP: IPv6
- Network Management Tools: BRAdmin Light, Web-based Management, BRAdmin Professional, Web-BRAdmin
- Linux OS Support: Red Hat, Mandrake, SuSE, Debian PostScript3 PPD
- Power Requirements: 120 VAC +/- 10% 50/60 Hz
- Energy Star Compliant: Yes
Nov 24, 2008 | Office Equipment & Supplies
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Ricoh Aficio CL3500N Laser Printer Logo
152 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
