Question about Samsung BlackJack Smartphone
Hands free answering of phone calls
I recently bought a new BlackJack II and a Motorola H371 blue tooth. How do I get it to answer automatically? My former cell, a Motorola Razr with a Motorola HS850 would answer calls after the second ring without me having to do anything. I wear it riding my motorcycle and it is very convenient for it to answer all by it's self. How do I configure my BlackJack and H371 to do this?
Thank you,
Rudy
    Problem Solver:
  • 10 Answers
You go into the options then call settings and change it to automatic.
Posted on May 09, 2009
How do I listen to music on my h371
Hi
Actually this device does not have the A2DP profile so is unable to play music.
Regards
Marge
Motorola Mobility
Oct 02, 2014 | Motorola Mobility H371 Bluetooth Headset
Blue tooth pairing code t055
Hi, you can use the below instruction to know to pair with blue tooth..
How to Pair (Connect) a Blue tooth Headset to Your Phone
So you've heard of this new thing called "blue tooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Blue tooth cellular phone
* A Blue tooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the blue tooth menu.
On most phones, go to the settings menu, then to "connections" and then "Blue tooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Hands free" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Sam sung phones: **Blue tooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Pass-code", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or pass-code. I have never encountered a headset with a different number as a pass-code. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the blue tooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Feb 03, 2011 | Cell Phones
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I have this motorola n136 that I used with my old Samsung phone. Then I bought a new samsung and bought a new charger for the blue tooth and now I cannot synch the two together.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Dec 17, 2009 | Motorola Mobility Bluetooth Hands Free...
Having trouble connecting Explorer 320 to Samsung Blackjack II
Push And Hold The On Off Switch On The Blue Tooth Till It Flashes Blue And Red. Then Search For The BlueTooth When Found Push The Button On The Blue Tooth Again. Hope This Helps
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
Blue tooth headset automatic preset instructions to answer
this setting can be adjust by the phone settings. you just setup in the profile to answer automatically, and you will have a 5 second delay automatic answer.
Aug 16, 2008 | Nokia Mini USB Bluetooth Dongle w/...
Bluetooth does not ring for certain calls
have u checked ur settings of the blue tooth I think the settings might be off and I request you to switch it on and try once again
Jul 14, 2008 | Motorola Mobility RAZR V3
Motorola H371
Guys, try to put in the number 0 four times, and that should work. I did it on my bluetooth and it worked. Good Luck !!
Dec 12, 2007 | LG KU990 Viewty
Hands free problem
lo m8 it sounds like a problrm with the ribbon that conneccts the 2 boards.try replacing it or you can send it to these guys to get it done. http://www.mobilephoneservicecentre.co.uk/
Jul 24, 2007 | Motorola Mobility RAZR V3
Samsung BlackJack Smartphone Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
