My cannon MP530 has a paper jam but there is no paper and the feed switch isn't working i've tried turning it off aswell as the computer for the night and nothing....any ideas
There is another paper jam door on the back side of the printer incase you didnt know . I had a paper jam and could not see just by lifting top of printer. You also may have a small pice of paper triggering the sensor.
Posted on Jul 27, 2008
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Paper feed jamms the paper all the time, will not feed without jamming from bottom tray, top tray jams every 2 to 3 prints or print with the top corner bent
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Oct 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
RE: MP530 ALL IN ONE PRINTER ripped paper stuck in printer
Open the printer from the back you should see if there are paper scraps there. note that if you did not switch off the printer before pulling paper, the printer may damage. but try opening the printer from the back it could help.
Jun 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I was unsing my printer when it jammed. I cleared the paper however, the alarm light keeps coming on. I have tried turing the printer off, turning off the entire computer, turning the printer and computer...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
Cannon Pixma 450 Paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 27, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP150
This same prolem has plagued many with the MP150 cannon printer, Here's what I did to fix this...E3 code shown in window
when no actual paper jam could be viewed ! I did the restart thing
by turning the printer OFF and waited (10) seconds or more, then
when I turned it back on...I listened to here the feed rollers turning
and forced feed a sheet of paper into the feed rollers..and sure enough OUT CAME a small piece of paper..actually a small strip of glossy paper like a strip that might be attached to a part during manufactureing..any way that paper has printing on it, it says;
(nitto No.500) it would be interesting to know if others out there
find the same piece of paper !! Give this fix a try. Palcando.
Nov 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
129 people viewed this question
k24674
jasbo
jasbo
