Motorola Mobility H350 Wireless Headset Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesnt turn on
I've had my headset for over a month and it worked fine with my ps3 and my phone and over the past couple of days it hasn't turned on.
ive charged it and tried to turn it on, but there's no response. =(
help, please
Anonymous
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Aug 09, 2008
Anonymous
Expert
Level 2:
New Friend:
Answers
101
Questions
Helped
41487
Points
208
THE BATTERY OF BTHS IS FAULTY .
How do i connect my motorolla hz800 bluetooth to ps3
I think i've figured it out. I have turned the multi-point connection off and then paired the Finiti with my phone and PS3 separately. Just make sure that you have your phone's bluetooth connection or other device turned off before turning on your PS3, and then make the connection between Finiti and PS3 and you should be good. Then when you're done using the PS3, and its powered off, you can turn the phone BT connection back on and you should be good.
No audio
not sure about the bluetooth settings on an Iphone sounds like the speaker may be broken. have you tried pairing it with another phone if it works on another phone its probly just settings
2answers
Ps3 afterglow headset is not working??
mine headset is blinking and it don't work or turn on. please help me
My H710 will only connect to my htc smartphone if I go into the bluetooth setup and select the device. otherwise when I open the h710, the phone indicates it is paired but not connected. for hte first...
i find that it will take my phone awhile if at all to connect to my headset if I turn on the headset first. Headset off turn on bluetooth in the phone, wait a bit, say a minute then turn on the headset. As for the H710 you can probably get the manual from their website to try reconnecting it.
Try to connect it to my boost mobile phone and the phone does a scan but doesnt picks up the bluetooth signal from the headset
Try this:
First, turn your bluetooth headset off. Then, start the scan to locate the headset on your phone. Just as the scan starts, turn your headset on. You may have to do it a couple of times to get it to work - but most headsets only go into pairing mode for a short few seconds just after being turned on.
Mic does not work on new 510 headset
sounds like a defective unit the mic doesnt mute
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
