Question about Roper REX5635E Dryer
The dryer heats up & spins,clothes don't dry,lint areas are now clean
I have a kitchen aid dryer which which spins and heats up but wasn't drying clothes ,we have cleaned out the lint areas real good what else could it be
  • 1 more comment
  • dfcp Jun 05, 2008
    thanks for the help
  • dfcp Jun 05, 2008
    awaiting answer
  • Anonymous Mar 16, 2014
    kitchen aid dryer tumbles but isnt drying
    President:
  • 1,314 Answers
Restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Posted on Jun 05, 2008
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Dryer heats sometimes and other times it does not. tested heater element and fuses and they were good. replaced both thermostats and it still does not heat well. any suggestions
You did not post make or model, so I can't be certain what technology your dryer employs or it's age. Here is my suggestion... Have you cleaned the lint trap area all the way to machine exit? How about the hose to the outside, is it clean and not bent or restricted? If there is a restriction, the steam cant escape and and it will take forever for the clothes to dry. I'd also check to see if there is air coming out the exhaust. If not, check to see if the fan is clogged with lint, intermittent or missing. If no air flows through the drum, it will keep it hot and moist, and never dry the clothes.
Jun 17, 2012 | Dryers
Our Kitchen Aid Gas dryer is heating, but not drying the clothes. Can this be fixed?
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 19, 2011 | Dryers
Clothes take long to dry on Kitchen Aid Model - KEYE660WWHO
First thing to do is vacuum out all lint from dryer, unplug, remove back and vacuum all lint out of it, also where vent hooks up. Then clean out duct work from inside of home to where it exits. Excess lint holds moister and causes dryer not to dry.
Sep 27, 2010 | KitchenAid KEYS850LQ Electric Dryer
Dryer is taking too long to dry
Dryer needs to be cleaned. Unplug, take off back and vacuum all lint out of dryer, also take off vent and vacuum inside of vent area. Then clean dryer vent from inside of house to where it exits. Make sure all lint removed. Lint holds moisture and causes dryer not to be able to release steam caused by heating wet clothes, thus clothes don't dry.
Jun 09, 2010 | Kenmore 66972 Dryer
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
Dryer is spinning and warming up but it's not drying
Exhaust full of lint. Vacuum into dryer exhaust as far as you can, Then clean out complete vent from dryer to outside. Any lint will catch moisture and clothes will not dry.
Jul 21, 2009 | Dryers
Dryer heats up ands pins, but it takes forever to
Hi, First thing to check is the 4" venting to the outside. Make sure it is free of any lint and that there are no kinks in the hose. If this is a gas dryer, the couls on top if the gas valve could be getting over heated and not opening the gas valve later in the cycle so there will be no heat.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Dryers
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
146 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
