Question about Mitsubishi WS-65869 65" Rear Projection Television
Color is going weird
When I watch my mitsubishi ws-65869 after the tv has been on for awhile the color will start to look funny and then eventually completely go out leaving me with a black and white picture.
  • 979 Answers
Chroma IC is to blame, but before you go replacing it, be sure that the power supply voltages are correct....accordianman
Posted on Jul 14, 2008
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
It looks a great deal like watching a 3d movie without 3d glases. The convergence is not correct. I tried to correct with a convergence back to factory settings and a manual correction from the remote. Not...
Common convergence problems like this require the set to be repaired. Transistors are used to control convergence and they will go bad eventually and require replacement. Expect a repair cost in the 100 to 175 dollar range depending on who you can find to complete the repair.
May 04, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I think the color bulbs are going out. I called
3D pic?Ur convergence it dead.U know how to solders?Tries these websites for convergence kit.Use replaced what in the convergence kit. Tv repair World.com,or Tvrepairkits.com.
Dec 14, 2009 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
In your On Screen Display menu (OSD), you should have a place that says "convergence". As a sub heading to this it will say "Auto-Convergence". This is where you want to be! Hit OK under AUTO, and watch the magic happen! If your set happens NOT to have AUTO, you'll have to do it manually. You're going to make the lines all match up doing one color at a time until all three colors are done! It's not hard at all. It may take a little patience at first, but just think of all the money your saving by not having a TV tech come out to your house and you'll be fine!
May 31, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" Rear Projection Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
