Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Disabling firewall? i cant figure out how to log into my modem and turn the firewall off? i cant find the number on my box for the URL to get into it, and sense my roommate set it up i dont know the user name or password to log in once im there? any advice?
  • smshurett Jun 25, 2008
    I am trying to access my router to put a password on it
  • Anonymous Mar 24, 2014
    Zyxel 5001z modem/router, who do I clear web actvity
  • 48 Answers
By default, you can get to the surfboard configuration page by http://192.168.100.1. username: admin / password: motorola
username and password are case sensitive.
if you dont know the password better get it from your roommate to avoid resetting the modem back to factory defaults. if there's no other way to retreive it you can reset it by pressing the reset button on the back of it for 5-10sec.
after resetting, according to the manual, the modem might need 5min to 30min to sync again with your ISP.
Posted on Jun 06, 2008
Cant log in to mandspeoplesystem on my chromebook
Try temporarily disabling your firewall. If successful, you will need to open ports to allow for this URL to pass. You can find out the I.P. needed by browsing the logs in your firewall.
Dec 31, 2013 | Acer Cromia Chromebook PC Notebook
I am trying to log into my router to change the NAT type, So i reset the router as the default username and password. Now when I click on the router in the start menu, it switched the router off? I am...
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | NetGear DG834G Router
How do I turn off the belkin firewall so I can play xbox 360
type 192.168.2.1 in the url box in your browser open the belkin router page
left down colum bottom you wil find firewall ->if prompts password click submit - > disable firewall
Sep 04, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i turn off the modem firewall?
If your modem/router is connected via ASDL or Cable then open internet explored.
look below the router/modem and it should have the IP address of the box (ie. http://192.168.1.1 )
Type this into internet explorer.
It should take you to the log on page.
Again read the modem/router though if you cant then try user name ADMIN and password PASSWORD.
This will log you into the modem setup. Click firewall/security and switch it off........Get the model of the modem then type it into google and you will find a more detailed guide of the unit.
Jul 08, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I want to diasble my router firewall and cant fiquere where its at
Disable router firewalls by logging in to the administration interface of your router and looking for a firewall section.
To log type http://192.168.0.1
The administration interfaces differ depending on the manufacturer and model, so your wireless router might not have a firewall section. If it does, click on that section and turn off the firewall.
Step2Forward a port. If the firewall is preventing an external computer from connecting to your internal client, you will need to forward a port to your client. Step3Find your internal IP address. Step4Click on "Start -> Run..." and enter "cmd" into the box. When the command-line pops up, enter "ipconfig" and hit "Enter." Find your IP address in the statistics that are printed out. Step5Refer to your software's documentation to find which port number must be forwarded. Step6Log in to your router's administration interface. Step7Click on "Port Forwarding" or an equivalently named section. The name of the section will differ depending on your router's manufacturer and model. Step8Add, on the correct port, a forward to your IP address. You will have to update this port forward in the future if your IP address changes. If your IP address changes often, ask your network administrator for a static IP address. This will fix your problem. Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Cant connect to wireless network set up in my home. will connect for a few seconds and then say that I cant be logged on to the network
Try going to the manufacturers website and find out how to access your router. Then try disabling your hardware firewall. You can also reset your modem and unplug all connections for about 10 secs and then do it again. I had that problem with a linksys router and I would get booted all of the time.
Jun 11, 2008 | Belkin Computers & Internet
Firewall
If you are referring to your connections built in firewall then goto network connections and right click on the item and select properties. If there is a built in firewall to the network device you will see it in the list. Uncheck the box to disable it.
Apr 28, 2008 | Siemens Se5954 (120-5954-003) Firewall
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Two Fire Walls!!!
Perhaps you need to forward a port
Dec 13, 2007 | Arris Touchstone 450a (CM450) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
795 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
