Question about GE JVM1653 Microwave Oven
Door inside and metal vent area smells strongly of fumes
My microwave smells strongly of some type of fume. This smell is there on the inside of the door and on the vent (fan) area below. This smell is there even though the microwave is not in operation. The microwave seems to work fine otherwise.
My gas stove below emits no odor at all. The smell is stronger when I put my nose close to the inside frame of the door. This is making me nervous. Ever heard of this? Is it dangerous?
Cindy
  • William Miller
    William Miller May 11, 2010
    What does it smell like?
    How old is the microwave?
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Posted on Aug 27, 2008
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
FMV152KBA
When a microwave gets a strong smell and then just stops working actually this means that something is bunt down in it, more of so the strong smell indicates that the HT (high tension transformer) inside has its windings burnt. If replaced check that while its on, its vent holes on the sides or at the back is not blocked, this helps it not over heat. Also check that the fan inside is working or else replace it too.
May 26, 2014 | Frigidaire Microwave Microwave Oven
I have a R-8520 Sharp carosel microwave. Previously the convection stopped working, now it does work but heats up too much to the extent that fumes come out from the back of the microwave and it smells of...
I think it might be a good idea to consider having the appliance replaced, the unit is a fire hazard and judging by the burning smell it is on the way out.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
There is an oily smell when I use my new Danby Microwave. Is this normal? Will it get less ? Is it harmful? Ty
If it affects the taste of the food I would definately return it for a full refund before the 30 days are up.
Jan 20, 2010 | Microwave Ovens
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
No Exterior vent for fumes
Hello kbender,
I am absilutely certain that the reason it vents inside is because it is more difficult to vent it outside.. ( which means it costs the builder more to do that) but to answer your question.. Yes, all spacemaker micros can be vented out the wall but you will have to remove it from where it is mounted and rotate the blower assembly so it vents out the back, place a blank off plate over the open area where it used to vent ( it may be there and needs to be repositioned when you rotate the blower) , then create a vent hole that lines up with the exit point of that micro.. and attach duct work to bring it outside ( depending on your siding , will dictate how that gets mounted externally and you may run into a problem witha stud on the outside wall ( a bearing wall) that wil need to be cut..I've installed many of these to outside vents and it is a lot of work.. so you may want to consider your options. If you hire someone, that's the easiest solution. You may also want to check to make sure your condo committee ( if you have one) will not have a problem with that.. or you may be able to get a group discount if you hire someone to do mulitple units..
Hope that helps..
Regards,
Rick
Dec 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Aug 30, 2008 | Microwave Ovens
Vent door opens when I turn on vent Fan
Your best bet is to have a look at the owner's manual and installation instructions, which you can find here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
GE JVM1653 Microwave Oven Logo
421 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
