Question about X2Gen MG19MY 19" LCD Monitor
I have 2 identical monitors that i use for my studio
And one on the left has started casting a hi hiss sound onto my audio path. if i shut that monitor off, the hiss goes away. the only thing that is plugged in from that monitor is the power and the monitor cable to my G5 tower. I have tried switching cables, same problem. any ideas? the other monitor works fine.
    Habit-Forming:
  • 111 Answers
They are sitting right next to each other?
sometimes you have to space electronic out, due to there out put... if they are really close to each other try moving one and see what happens.
hope this helps
Posted on Jun 05, 2008
Strange hissing sound and smell comes from the monitor
Whenever you experience an unusual smell coming from anything electrical, always turn it off and/or disconnect it from any power source until you learn more about the problem. A fire can make make any problematic device seem suddenly unimportant.
An extremely common component in nearly any electronic device is a capacitor. The sizes vary from baby-tooth-sized to bowling-ball-sized found in the power box for most photography studios. The hissing sound is likely caused by one of these. The noisy capacitor may be going bad or another component or an electrical short may be causing it to get too much power. I've attached a video of what happens when capacitors get too much power.
An electrical short could also be causing both symptoms. If the smell is similar to burning organic matter, you likely have an insect (a crispy critter) that can be removed to remedy your problem. However, an electrical burn usually releases gases from burning rubber or plastic and has a distinctly different type of odor. If that's the smell and you are handy with a soldering iron, remove the cover to your monitor and look for signs of burning or overheating. Otherwise, the task should be left to an electronics shop for repair.
If this information was helpful, please click the thumbs-up button below.
Oct 23, 2012 | LG Computers & Internet
My studio monitor keeps shutting off!
It's shutting down automatically due to heat peaking. You need to turn off until you are ready to use it.
Apr 11, 2012 | Adam Audio Audio A8X Powered Monitor
My studio monitor, after it is at a healthy volume for a while starts to pop and distort.....and when I turn the volume down the monitors puts out a hard hum, pushing the speaker out.....does this sound...
That does indeed sound like a failing capacitor. If you want to repair it yourself look for a 1 or more capacitors with a crack in the top. You will need to replace the capacitor with an identical rated one. Otherwise you will have to replace the monitor. Be extremely careful as capacitors can hold a deadly electric charge even when unplugged and turned off.
May 02, 2011 | IKEY-AUDIO M-606 POWERED STUDIO MONITOR
I have a st69 and every time I record, the vocals while recording sound very chorus like in the headphones, but they sound fine when I listen to the play back, please help.
Check the mixer settings to be sure you are not sending multiple mixes or effects to the monitor (headphone) output. The output used for recording does not necessarily have the identical sound sources and mixing path as the headphone, so make sure the headphone is monitoring the same signal as the recording output.
Feb 07, 2011 | Sterling Audio ST69 Microphone
Hi, I have a 304 NAD amplifier which occasionally distorts on one of the tweeters. I have taken it for repair several times but no one succeeded in fixing it. I have not replaced it because I am so...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 04, 2011 | NAD Audio Players & Recorders
Tapco Link.USB Not Working Properly
ITS THE PORT OR THE HEADPHONES,PROBALLY THE PORT.
Nov 22, 2009 | Bob Mackie Tapco By Mackie LINK USB AUDIO...
Problem with DELL 2408WFP
I have similar problem.  I'm using the HDMI connection from my PC to the monitor and when I connect my audio out from the monitor I get hissing and popping sounds along with the audio.  It sounds pathetic, I also hear the music and audio along with the hissing and popping.
If I connect the audio to the back of the PC the sound is crystal Clear.  I am using Vista 64 bit with NVIDIA GeForce 8600 GT video card.  Trying  to Google to see if others are are seeing the same problem.  I just got my monitor on Oct 6.
Sep 30, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Monitor won't turn on.
Does the cord plug directly from the wall into the monitor, or is there a power "brick" adapter between?
If there's a "brick" listen to see if the hissing is coming from the monitor itself or the brick. If the hissing is coming from the brick you may just need a new power adapter.
If there's no brick or the hissing is coming from the monitor, the monitor probably needs repair. With the price of LCD monitors these days compared to the price of labor, you're probably better off getting a new LCD monitor. Just make sure you take your old one to a proper E-Waste facility so it doesn't pollute the environment.
Apr 05, 2008 | Gateway FPD1760 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
60 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
