Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
NOT FOUND device... =S
Whenever I try to send sth to the calculator, all port presents: «Not Found» in the Device column...
Can You help me try to solve this problem please?
If you can, send me the answer to my e-mail: mariana12_02@hotmail.com
Thanks*
You must install the latest version of TI-Connect
Posted on Mar 24, 2009
  • 21 Answers
Reinsert the cable to a different USB port
Posted on Jun 11, 2008
  • Anthony Li Jun 11, 2008
    reinsert the cable to a different USB port
TI 84 plus having problems software?
I cannot understand what happened to your calculator but ther is a way to restore it to health.
The operating system OS and all the applications that were preloaded in your calculator are available to download freely from http://education.ti.com.
Use the tab Download--> Apps and software. Then select the OS for your calculator TI84 PLUS and save on your computer. While you are at the site download the TIConnect, if you do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html
Install TI connect on your computer and run it to open the main window.Then connectyou calculator to a USB port and, in the TIConnect main window Clickthe TIDeviceInfo icon. Software will try to retrieve the info. If itdoes your calculator is ready to communicate with the computer.
Ifit tells you Device Not found , Click communication settings in samepop up window where it said Not found, and Select Device, Select Cable(USB or TIsilver cable), Select Port (USB1) and Click OK..
Ifyou are lucky and it works, you can reinstall the OS. You drag and drop the OS on theTIconnect main window. Calculator must of course be connected to computer and trurned ON.
Now that your OS is installed you can go back to education.ti.com and download all the applications you want. Drag and drop an application onto the main window of TIConnect to install it.
If you have problem with TIconnect, usethe calc-to-calc cable to transfer the OS and any application from a working calculator.You should be on Receive mode [2nd][Link] --->>Receive. (Whenboth calculators are ready hit enter.) The other calculator, youguessed exactly right, must be on Send [2nd][Link][SEND][Send OS]
Hope it helps
Oct 03, 2009 | Texas Instruments TI-84 Plus Calculator
Can't receive programs from another calculator when linked. Already checked memory.
Does you calculator have a communication port (USB, or serial). Hard to tell for a generic TI.
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there. Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
Hope it helps
Sep 14, 2009 | Texas Instruments Office Equipment &...
I recently put batteries in and it wont turn on
First you should try to reduce contrast
1.Press [2nd] yellow key and release it
2.Press [DownArrow] key then release it
3. Keep doing the 2 steps in sequence untill the screen is lighter.
If that does not solve your problem
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
Sep 14, 2009 | Texas Instruments TI-83 Plus Calculator
I was having the same issue
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK..
Hope it helps
Sep 13, 2009 | Texas Instruments TI-83 Plus Calculator
My ti-83 does not come on it just shows a black line when it does comes on. thanks, don
Hope it helps
Aug 13, 2009 | Texas Instruments TI-83 Plus Calculator
My calculator wont work
Hello, First you should try to reduce contrast Press [2nd] yellow key and release it Press [DownArrow] key then release it Keep doing the 2 steps in sequence untill the screen is lighter. If that does not solve your problem
Hope it helps
Jun 29, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 types numbers or shows menus upside down now
You sould reinstall the operating system.
Hope it helps
Jun 20, 2009 | Texas Instruments TI-83 Plus Calculator
Texas instruments ti-83 plus. only have black line on screen
Reset the calculators memory [2nd][MEM][7:Reset][1:All Ram][2:Reset]
If that does not work
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
Hope it helps
Jun 18, 2009 | Texas Instruments TI-83 Plus Calculator
I am trying to download the new OS for the ti 89 titanium but i am not sure how to get it onto my calculator.
Use the link below to download TIConnect software
Install it on your computer and run it to oppen the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
Hope it helps
Dec 08, 2008 | Texas Instruments TI-89 Calculator
Calculator
You can capture the calculator screen and send it to the computer. From the computer you may able to print it.
When the connection between calculator and computer is established, you click Screen capture and the image appeares in the TIconnect window. save the image in jpeg or png format. By default Ticonnect saves images in folder My TiData.
Hope it helps.
Hope it helps
Sep 07, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
278 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
