Question about Asko T700 Electric Commercial Dryer
Replace belt motor runs but tumbler does not turn. Opened up saw loose belt but not where to install it.
  • Anonymous Aug 25, 2008
    how to replace belt
A belt replacement problem solution has been posted above. However, to install a new belt the top and back of the machine will have to be removed so that the belt can be slipped off the back of the drum.
Before replacing the belt, I recommend checking the tensioner pulley that is located at the back of the dryer motor. The tensioner pulley is a plastic pulley with a spring attached. Your belt may have come off the tensioner pulley which would mean that it is too loose to drive the drum.
Hope this helps
Posted on Sep 17, 2008
The motor runs but the blade does not turn
UNPLUG the saw! IF your saw is a direct drive; either the blade is loose or the center of the blade is broken, Or the motor shaft has broke off. IF your saw is BELT DRIVEN, check the belt tension, or belt condition.
Jan 20, 2014 | Delta Saws
Tip
The motor is running, but the drum isn't spinning.problem with dryer.
Nine times out of ten it's a broken belt, but there are other factors that can cause this problem. <br /> <ul> <li>Broken belt -- Replace with an identical belt. Line up the new belt with the markings on the drum from the old one. Wind it around both the motor pulley and the idler pulley.</li> <li> Roller could be bad -- Underneath the tumbler is a roller that the tumbler sits on. It may have become too worn to work properly and may need replacing. Replacing it is simple - just remove the tumbler to gain access and then remove the retaining clip on the roller and slide it off. Reverse the process to install a new one.</li> <li> Motor or idler pulley could be bad -- Check the pulleys to ensure they're still in working order.</li></ul>
on Dec 24, 2010 | Dryers
My maytag dryer is making a clicking noise and the drum won't spin. I just changed the belt and still not working
That's an interesting one. Does the motor run but does not turn drum? If the motor is running but the drum is not turning then there is a possibility that the belt is not attached to the idler pulley correctly. Go HERE to see video on belt install. I have also ran into the screws that hold the tumblers in the tub loose and making noise. Check to make sure there are no screws sticking out of the tub. Contact me at http://www.apcoplus.com/contact.php if you need more assistance or just comment back on FIXYA..
Apr 30, 2013 | Dryers
I have a whirlpool dryer and when you push the start button the motor just humms and the tumbler doesn't spin. i opened the door spun the tumbler and push the start button and closed it quick and it...
You need to test it, but when the drum doesn't spin on its own, that more than likely means the motor is going bad. If you remove the belt from the motor pulley and run the motor with no load on it for a few minutes and then reattach it see if the motor runs this way, you may get a few more runs out of it. You can usually access the belt pulley form the rear compartment of the dryer.
May 12, 2010 | Dryers
Belt came off try to replace but to big
You may have a tension pulley on it which you will have to run the belt through to make it tight. This is primarily for making it easier to put on. Also check the motor bracket that turns the belt and see that it is still in place and not loose. This can happen over time with all the vibration that occurs. Let me know how this turns out.
Jan 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Dryer will not move but power good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
  • Remove the belt.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Drum problem
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Asko T700 Electric Commercial Dryer Logo
227 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
