Question about Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 possible leak?
Thanks to this site I found one of the leak problems in my washer which is the rubber ring around the door.
My wife is complaining though that the trap door on the bottom right corner of the washer should be completely empty of water when the washer has completed a wash. I don't know what that is called but it seems to be some sort of trap.
So if I open that immediately after a wash, would there be some water spilling out or should it be bone dry? If it is supposed to be dry, does this mean that the hose is plugged or something?
    President:
  • 1,294 Answers
It is normal that there is water in the trap, which is your filter. You clean this not after every wash, it depends on your usage. I have my machine trap looked into once in 2 months; i use it once a week. Of course i clear all pockets of clothes before i put them in machine.
Posted on Jun 05, 2008
Can't get retaining rings back on boot gasket on Bosch 3200uc
You can google for them or look on this site Fixya for spares.
Mar 19, 2013 | Bosch WFMC 3200 Front Load Washer
My washer will not lock therefore it will not start. Wondering if there is a relay switch problem that communicates to the door to lock it
Possible that there is a fault in the controller unit that does not activate the door switch. It can be a fault in the circuit or it can be silly as a connection fault, loose joint, fault lock mechanism or a door switch fault.
Dec 31, 2012 | Bosch WFMC 3200 Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Wfmc 3200 fixed E04 problem, where does the gasket go?
Take the cap back off. Put some pipe thread sealent on it. Just some basic pipe thread tape should do the job.
Feb 13, 2009 | Bosch WFMC 3200 Front Load Washer
Rubber gasket Bello!
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
BOSCH WFMC3200UC WASHER
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
147 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
