Question about Nintendo DS Lite Console
Ds lite charging problem
My ds doesnt charge up when plugged in - just the green light flashes. When its plugged in to charge up I cant play it either - the light stays red. Could it be i need a new battery. I know I use it a lot but i havent had it for that long (about 5 months)
See if you can move it to a different outlet. There could be another solution. If you have 2 Ds's make sure that they're not on the same outlet. If one of the plugs is upside down, it sometimes won't work. See if these ideas will help... and by the way, i don't know why you can't play it when it's charging.
Posted on Jun 05, 2008
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
What does it mean if a ds lite red light doesnt show up when you are playing it? The green light is on and plays fine but then when battery gets low the green light goes off and stays off but the red light...
This is OK the Red LED Has just gone out... simply just keep an eye on time if you think that it might die soon plug it in... there is not much that you can do to fix it.
Nov 21, 2010 | Nintendo DS Lite Console
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
Red LED light?????
Nothing, that just means it is charging, when it goes off, it is fully charged
Jun 11, 2009 | Nintendo DS Lite
When plugging power to the DS lite the led flashes orange once
I think if the orange light flashes once it means it has a full charge.
Mar 18, 2009 | Nintendo DS Lite
How to help me with my nintendo ds lite
If your DS is fully charged and a green light flashes on when you try to use it and maybe a screen flashes on, than you should try a new battery. Batteries lose their charging capacity after each charge.
Mar 07, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds power problems
mmm not exactly because if you plug the charger back in it will go orange again, so my guess would be that the ds doesnt stay charged for a long while, you can charge the ds properly when it is shut off but it does needs to be charging at least 8 to 10, you want it to last longer, play a game till the power goes just dnt save anything incase the ds shuts down while saving, otherwise it can corrupt the game and possibly the ds
Jack
Mar 12, 2008 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
83 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
