Question about Sirius ST3TK1 Satellite Radio Receiver
Dropout I am now getting "aquiring signal" all the time. It was intermittent but now is hard failed. The system is about 18 mos old installed in a 2003 Mitsubishi Lancer. What is the likelihood of the antenna going bad?
Give up
Posted on Jun 22, 2008
How di I fix a connection to broadband router failure
Hit the RESET button on the router. it will set it up again.
Oct 19, 2014 | Televison & Video
Laptop keeps turning off/restarting every 3 seconds, repeats...
Please check if this laptop has an overheating problem. If it has an overheating problem, then please check the air inlet, outlet and fan (if fan does not spin, then you have to replace the fan). If it does not have an overheating problem, then you can test the laptop using another hard drive with a fresh operating system. If it still has a problem, then it means the motherboard is bad.
Feb 13, 2014 | Computers & Internet
Odometer won't work unless headlights turned off, radio lights dim, blinker won't blink all the time now battery light comes on but battery tests good. Intermittent issues getting worse. Horn
You probably have a bad ground in the electronic instrument cluster, or cluster connection to wiring harness. I would recomend you have a qualified auto tech diagnose it. It is not a easy fix.
Mar 16, 2013 | 2000 Ford Expedition
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Garmin nuvi 200w not getting any signal....
I recommend trying the hard reset and the newest webupdater (March 31, 2010) and se if you get better results.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 08, 2010 | Garmin nuvi 200W GPS
Mailbox inactive
You can have this phone on one of many different Nortel phone systems and you can also have different voice mail systems. If your voice mail is old and based on a hard drive it could be failing. Chances are your voice mail is the problem. This can get very complicated for someone not familiar with phone systems and voice mail. I would highly suggest looking for a local phone system installation company that can come out and troubleshoot the problem. If your voice mail is 10+ years old and based on a hard drive you may want to replace it regardless instead of wasting time paying a tech to find an intermittent problem. A hard drive running 24/7 for 10 years will not las much longer anyway.
Nov 16, 2007 | NorStar M7324 Telephone
Persistent error message
The latter symptom (the rapid clicking sounds), is one of a failing hard drive.
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Disappears from system
right click my computer click hardware click device manager look hard drive
Sep 16, 2007 | Maxtor OneTouch II Hard Drive
Sirius ST3TK1 Satellite Radio Receiver Logo
418 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
