Question about Dryers
Maytag Neptune MDG9700AWW gas dryer. Problems is the dryer runs for 3 hrs when drying clothes
  • ojchap Dec 12, 2008
    I thought this was an energy efficient appliance. How can that be when I've had loads take up to 3-3 1/2 hours to dry, and I have the sensor set to "Normal Dry"?  If i use timed dry the clothes are still quite damp/wet after 45 minutes. I don't understand this, I even clean the lint trap after every load.
  • Anonymous Dec 30, 2008
    For color clothes dryer takes 5-8 hours.
    Genius:
  • 1,028 Answers
Be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Posted on Jun 06, 2008
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer doesn't dry (flame cuts out)
279834 is the part number for the 2 coils ( kit ) which mount on the burner . Only 2 screws hold the coil retainer . One coil is opening ( shorting ) after it gets warm . Replaceing both will solve the problem . Easily replaceable .
May 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Does not heat up
maytag neptune gas dryer runs but does not dry clothes i smell gas initially when i turn it on
May 07, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MayTag Neptune to Propane
buy the lp conversion kit from one off the links here at fixya and it comes with instructions
Jan 01, 2009 | Maytag Neptune MDG9700A Gas Dryer
go to sears.com to get the conversion kit which will contain detailed instructions.
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
910 people viewed this question
Top Dryers Experts
