Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Dryer won't start
Hi, just moved into a new place and the washer works, but the dryer does not. Are there some simple troubleshooting steps I can check before bringing out a repairman?
Thank you,
Suzanne
  • seattlehomes Jun 09, 2008
    Will check. Thanks
  • Anonymous Dec 13, 2008
    The washer works fine. The dryer does not turn on in any mode. The breaker is fine since the washer still works. Any ideas?
    Novelist:
  • 177 Answers
Check and make sure the power is on at the breaker box, or fuses.
Start at the power source.
Posted on Jun 07, 2008
Dryer wont start
Hi firew34 - If the dryer will not allow you to operate, try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, control board or door switch.
May 03, 2013 | Frigidaire GLET1031FS Top Load Stacked...
Auto dry not working on stack washer/dryer
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Sep 12, 2012 | Kenmore 98702 Stacked Washer/Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Dryer works, but does not get warm enough to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint wd420 washer dryer dryer is not heating up
heatman101
Mar 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryer wont heat
heatman101
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE3 washer and dryer will not lite (begin cycle)
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
Sal DeAngelo
fordexpert
Ed Mac
