Question about Radio Shack Pro-96 Scanner
Pro-96 antennas I bought a antenna from Fry's(its HUGE but supposed to pick up further away.) since I put it on my scanner none of the other antennas work(like the regular 800 MGHZ) Only sometimes the police. Radio Shack is clueless. There is no "A" on any of my channels. The antenna is gold instead of chrome. Dont know if that means anything????? PLEASE HELP me.
  • 127 Answers
It will only work with a crome antenna.
Posted on Apr 17, 2009
  • kathy ditterline
    kathy ditterline Jun 20, 2009
    I would make sure you have
    the new frequency # put in scanner
    GOOGLE free new scanner frequency #
    put in your town and city.
2 Suggested Answers
  • 3 Answers
Have it recloned and see what happens.
Posted on Aug 17, 2008
How can i get my indoorantenna to work?
If the station your trying to pick up is over 30 miles away forget it. Put it outside or in a window that faces the tv station you want to get. Or get a good antenna and put it outside.
Sep 03, 2014 | Electronics - Others
In moving we lost our antenna.. we can pick up the weather chammel with out a antenna, but that is all.. what kind of antenna do we need?? Radio Shack does not have anything they said would work.can you...
You need an antenna with a Motorola plug, also known as an automotive plug, and a 90 degree angle - or a swivel. You can pick one up on any of the scanner web stores (Scanner World, Scanner Master, Grove Enterprises, etc.) or on eBay. Here's a link to a current eBay listing:
Bill B.
Listening in since the 60's
Jan 04, 2011 | Uniden BC248CLT Base Scanner
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
Radio Shack PRO197 works at friend's house but not at my house!
This seems to be a common problem with all digital systems (especially with TV signals), and the ONLY solution is a better antenna. I suggest you search eBay, Scanner Master, etc. for a low-end (price-wise) discone and mount it as high as you realistically can.
The BEST scanner in the world is only as good as the antenna that feeds it!
May 30, 2009 | Uniden BCD396T Handheld Scanner
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is...
try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Nov 12, 2008 | RCA Televison & Video
Antennas Uniden Bearcat BC148XLT
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Sep 09, 2008 | Radio Communications
Jun 05, 2008 | Radio Shack Pro-96 Scanner
Not picking up channels.....
is the antenna gold or chrome? I know that if it gold they dont work as well.
Please help
The signal received on scanners depends on a number of factors. The most important is the elevation of your location. If you are in a valley or have higher ground around you, this will screen signals from you and will reduce the number of stations you can hear.
Secondly, receivers vary enormously from one to another. The one you are using may simply be less sensitive.
Thirdly, the position and type of antenna is crucial. If you are using a directional antenna it will only pick up signal from the front and some from the back. An omni-directional antenna will allow you to pick up signals through 360 degrees. The antenna must also be as high as you can get it, especially if you are in a valley.
Some emergency services use repeaters which allow you to hear signals much further away. You may not be in range of a police repeater.
Mar 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Mazda MPV Radio Problem
Mar 05, 2008 | Sony CDX-L410X CD Player
Radio Shack Pro-96 Scanner Logo
107 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
