Question about Radio Shack Pro-96 Scanner
Not picking up channels.....
I bought a antenna from Fry's for my pro-96. Now I cant get any frequencies unless I have that one on(it is HUGE). The regular antennas dont pick up the frequencies, accept sometimes the police. There is no "A" on any of my channels. Radio Shack is clueless. HELPPPPPP Would you mind calling me? or e-mailing me? njwike@hotmail.com
  • live2wire65 Sep 13, 2008
    I gave mine to the radio shack assistant and then two weeks later I went back and hell you guessed it they said it was fixed like hell it was fixed!
  • 56 Answers
The new antenna you bought might have had too big of a center pin in the connector and when you put it on the scanner it may have pushed down or widened the socket in the connector where it's supposed to fit.
Also, you may have just become accustomed to the better coverage you get with the big antenna to the point where if you put on the old one it almost seems like it's not working.
Posted on Feb 12, 2010
  • 127 Answers
Is the antenna gold or chrome? I know that if it gold they dont work as well.
Posted on Apr 17, 2009
  • kathy ditterline
    kathy ditterline Jun 20, 2009
    I would make sure you have
    the new frequency # put in scanner
    GOOGLE free new scanner frequency #
    put in your town and city.
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
I have the pro 96 for about 2 years and I can hear the squelch sound but its not picking up chatter.
Try turning the squelch to minimum, press Scan, or you may have to program it. To program, Press PGM, select the channel you want, press PGM, use the number key and ./DELAY to enter the frequency including the decimal point you want to store, if you make a mistake press CLR, press the ENTER button to store it. You can get your frequency's for your state at www.RadioReference.com ...hope this was helpful..
May 15, 2010 | Radio Shack Pro-96 Scanner
Turn it on, press the manual button,then rotate the squelch knob until you hear silent,press scan and wait to see if you hear transmissions,if not ,you may need to re-program it, to re-program, press manual,enter the channel number,press manual,enter the frequency you want including the decimal point, press E. If you make a mistake,press CLR to erase. You can get the frequency for your state at RadioFreq.com or RadioReferance.com. hope this helps..
Mar 29, 2010 | Radio Shack Pro-96 Scanner
Pro-96 antennas
It will only work with a crome antenna.
Jun 05, 2008 | Radio Shack Pro-96 Scanner
Pro-96 BAD ANTENNA
Have it recloned and see what happens.
Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Mar 15, 2008 | Radio Shack Pro-96 Scanner
My Pro-96 Suddenly Doesn't Pick Up Transmissions
on scan mode press (man) for manual then pgm then trunk. screen should read not trunked press mode. if it does say that then press scan, and it should work. but if it doesn't say not trunked then press mode until it does say not trunked, then press scan. should work.
Nov 23, 2007 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
142 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
