Question about Technics SL-1210 Turntable
They wont turn on
I have them plugged in but no power is going through either of them
  • 515 Answers
Check the fuses. If the fuses are good, then it's the transformer that is shot. The fuses are located underneath the turntable platter. If your unit does not have any fuses, then the only problem could be with your transformer. You can PURCHASE A REPLACEMENT TRANSFORMER HERE.
Good Luck!
- Davis.
DIGITAL ANALOG THERAPY
Posted on Jul 02, 2008
Reset and test button on plug wont go back in
with no power going to plug it wont reset , mcb or circuit breaker need to be in on position, is there power at plug( socket )? can you post pick of set up ?
Jul 01, 2012 | Frigidaire Heating & Cooling
Regular xbox wont turn on worked fine yesterday now wont power up like it is not plugged in but it is
You will need a new power supply go to game stop and trade your old one in they will give you a discount and get a rebuilt one they go out a lot.
Chris Thrash
B52Computers
Jan 23, 2011 | Microsoft Xbox Console
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Jul 30, 2010 | Element Electronics FLX-1910 19 in. LCD...
My iphone wont work after resetting it apple logo on and off hard reset wont work computer wont recognise it either what can i do?
Turn it off, then power on holding home and power at same time. Count 10 seconds, then release power while still holding home for another 10-20 seconds. The screen should go blank but if plugged into computer iTunes will see it as phone in DFU recovery mode. Restore from iTunes and you should be good to go.
Jun 14, 2010 | Apple iPhone Smartphone
Replaced engine. car turns but wont start. power
have you checked that the points in the distributer are set ok and havent closed or burnt,as this is what makes the coil spark the ht lead to the distributer cap to the rotor arm then to the plug leads.
hope this helps
Aug 02, 2009 | Ford Contour Cars & Trucks
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Head set has power but wont turn on
have you tried look at the fuse on the back of the radio or if there is one on the battery power wire for your radio. check and make sure your ground is good and that both your battery and accessory wire have 12 volts to it. Check any and all fuses
Feb 23, 2009 | Sony Car Audio & Video
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
Wont turn on
" I HAVE A TOMTOM GO 300, THE GREEN LIGHT COME ON WHEN PLUGGED
UP. BUT WILL NOT TURN ON. I HAVE DONE THE RESET PROCEDURE.
Jul 31, 2008 | Tomtom GO 300 GPS Receiver
Technics SL-1210 Turntable Logo
186 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
