Question about Dewalt 18 Volt Compact Drill Kit
How do you get the brushes out
Actually only a 12volt,but how do you replace the brushes,I have some new ones but unsure just what is holding then in place,and acn this be done with just the end cover removed.
  • netherfield Jun 05, 2008
    Model No is DC981
    Sergeant:
  • 187 Answers
I was just about to type in that I had the same problem when I took a second look. I tunes out that all you need do is pry between the plastic brush housing and the center bearing hub. It just slides out, no clip or screw. With mine it turned out that the brushes were just hung up and once freed the drill ran fine.
Posted on May 05, 2009
    Champion:
  • 313 Answers
Need to have the model of the tool to held you out. some yellow
tool you have to pop out the brush assy
Posted on Jun 05, 2008
  • mr aicnelav Jun 05, 2008
    all i can find is dw980 & dc980. 12 volts drill. if you want parts diagram check dewaltservicenet.net or toolpartsdirect.com
    good luck
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
Coleman generator #PM0497000.02 generator starts well and runs smoothly, yet I have no electrical output. I have purchased replacement brush modules, but am unsure as how to re-excite the unit. The...
You have to get a cord that has a plug on on it. On the other end of the cord strip the insulation off the ends of the wire about an inch. It would be easier if you put small clamps on the stripped ends of the wire. Connect the black wire to plus on a car battery and white to negative. Start the generator and plug the cord in to a outlet on the generator just for a second and take the plug out. The generator should now be producing electrical current. If not there is something burned out internally.
Mar 11, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
When drilling drill comes to a stop easily.i can actually hold the drill and keep it from turning
Assuming you batteries are good you probably have bad brushes. They are located behind the vents-one each side- at the back of the drill. New ones are about 10 bucks from dewalt.
Feb 19, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Our Roomba 530 stops after few minutes saying clean the brush ,even after brushes are cleaned.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears
Mar 25, 2010 | iRobot Roomba 530 Robotic Vacuum
Over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Jul 31, 2009 | Tomtom RIDER GPS Devices
Trying to replace roller brush on DC07 model
Hi the dyson is a bit strange with this the dyson engineers use a hook to put under the belt and pull it out to allow the brush to be removed I used a metal coat hanger to make the hook after seeing the dyson engineer when ours was under warranty if you make the hook with the wire doubled up it works fine for me hope this is of help Fred
Jun 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Nov 19, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Stuck Brushes on My Hoover SteamVacV2 Turbine Help!
Did you pull the brush block out to see the the shaft hasn't broken off of the brush block? If so, then replace the brush block. From the bottom, take the screws, 2 of which will be longer ones, these hold down the turbine . Turn it over and the top cover should come off. There 2 posts at the back of the cover, they just fir tight but will come out. The turbine #23,is in the middle, near the front, remove the 2 screws on the front edge of it, unhook the tubing, it will come off. So you can take it apart and clean it out, or go ahead and replace it.
Aug 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
PROVIEW PL-456S LCD MONITOR TURNING PINK ON ONE SIDE
Chances are that you are not hurting anything with the lower power supply. What is probably happening is most likely two fold. 1. The light bulbs in the backlight circuit may just be wearing out and need replacement, and 2. the lower current power supply may not be capable of producing al the current that the monitor needs at certain times during operation. I would suggest getting hold of the correct power supply module and see where that gets you. If you still have the red outs,replace the light bulbs in the monitor. The only other fault than that would have to be in the video controller. Hope this helps.
Oct 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
Dewalt 18 Volt Compact Drill Kit Logo
330 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
