Question about NEC Dterm DTP 32D-1 Corded Phone
Turn up ring volume
This is actually a NEC Dterm80- how can I turn up the ringer volume?
  • Roni Flaherty Oct 04, 2013
    I do not see a "menu" button. In my function buttons it shows "List, Dir, ICM, and General Prog. "
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Posted on Apr 22, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
  • 121 Answers
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
I believe you can navigate through the menu and when you get to the ringer part push up on the navigation arrow. That should work. Thanks for using Fixya.Com.........Enjoy your evening!
Posted on May 30, 2009
Turn ringer volume up on NEC Dterm series i? I have tried adjusting while ringing but the LED volume shows up still
You need to lift the handset first then adjust the volume via the large silver round button on bottom right of phone
Feb 27, 2015 | NEC Lands Phones
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Phone rings but no sound
turn the phone up side down you can see the ringer switch on off and the ringer volume try to adjust them to on..then test the phone ringer if nothing happen the ringer speaker must be faulty and needs replacement..
Sep 30, 2011 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do you turn the ringer off of an NEC-DTU-32D-2?
you need to remove ringing programming in 4-01 for that extension. ldtsnj.com
Feb 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
How do you turn up the ringer volum
No way to change ringer type but you can press the arrow keys you use for volume while the phone is ringing and it will raise the volume. ldtsnj.com
Dec 19, 2008 | NEC DTU 8D-2 Corded Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Ringer volume
Adjusting the ringer will depend on the type NEC system you have. On the PRO II, Elite, and IPK just press the Speaker button and dial 601. The Phone should begin to ring and you can then adjust the volume with the up and down arrows.
Apr 19, 2007 | NEC DTU 16D-2, 770032 Phone (Refurbished,...
NEC Dterm DTP 32D-1 Corded Phone Logo
1,222 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
