My external hard drive don't work propertly it's a simple tech FV-U35/500 it was working good but now the computer can't detect it
  • 191 Answers
Try connecting it with another computer to make sure the drive is fine.
if its not i need to know are you using a USB HDD
if yes
try deleting USB ROOT HUB from device manager
press and hold the windows key (its between ctrl and alt on your keyboard)
while holding the windows key press pause/break key you will get system properties screen
if its XP you have to click on hardware tab and then choose devicemanager
the last option will be for USB in this list
right ckick USB ROOT HUB and click on uninstall or delete
restart your system.
then chek if its getting detected or not
Posted on Jun 05, 2008
Simple Tech 320GB external hard drive not working
If it started making noise it could be a bad hard drive. To test try to put your HDD to another pc and see if it sees your photos if it does back them up to google drive or One drive. if it does not most likely your hard drive had stopped working sorry please vote me 10 if I have answered your question
Dec 04, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
Hello , Are there drivers for Vista available for the Simple drive 160gb external drive Model number 900000-40479002 FV-U35/160
Once plugged into your computer, Automatic Update should find the drivers automatically and install them for you.
May 02, 2011 | SimpleTech SimpleDrive 160 GB External USB...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
Simple Tech external memory 1.0 tb not registering all the sudden
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths".
Give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Jul 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
First, check the warranty status. They should give you a replacement. The following will probably void your warranty... This external drive probably houses a standard hard drive used in a desktop computer. If you don't mind voiding your warranty, you could disassemble the protective "shell" and check to see that the cabling to the drive is properly attached. I've seen a external drive which the interface cable was partially unattached. If all looks OK here, you could remove the actual hard drive and try hooking it up to a standard desktop computer. If you or a friend is reasonably tech savvy, such is a plus. It could be set as a secondary drive, and then you could see if files could be accessed. If nothing above works, then your outlook is bleak. There are businesses specializing in file recovery from a dead drive, but it is expensive.
Aug 08, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
