Replacement bulb I need a replacement bulb for my 50" Samsung DLP. It needs BP96-00224C(P) Phillips 100W Where do I get these? Thanks, Chris Dampf Chris.Dampf@coors.com
  • 2,335 Answers
Check this website for the lamp. The cost is for the lamp only without the housing, but you could re-use the lamp housing by removing the old lamp and installing the new one.
Good Luck.
Posted on Jun 05, 2008
We have a 55 inch Phillips dlp tv. Today the screen went out. We have power and sound but after 10 seconds or so the only the screen goes black. Power and sound stay on but not the screen. On the front...
kristy alcor,
Sounds like a bad lamp. This is not a difficult replacement but the lamps are not cheap. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the replacement process, where to get quality parts at a good price and why you need to replace your lamp.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tip
Sony DLP Lamp XL-2400 How-To Replacement Guide. For Part Number: Sony Lamp...
For Part Number: Sony Lamp XL-2400 ( Sealed replacement lamp for televisions, SMALL & SEALED ).
Compatible Part Numbers: XL-2400, XL2400, XL-2400U, XL2400U, XL-2400E, XL2400E, F93087500, F-930-8750-0, A1129776A, A-112-9776-A
For Enclosure: Sony Lamp ( XL-2400 / 2-590-738 ).
Television Type: 3LCD.
For Bulb: UHP 120 / 100w 1.0 E 19.8
Philips UHP 120 / 100w 1.0
E 19.8 1.0 Philips.
on Mar 25, 2010 | Televison & Video
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
There is no picture on the screen the green light is flashing for it to come on then the sensor next to it turns red any help have changed the batteries in the remote and still no picture or sound thank...
It seems like the bulb needs to be replaced, the bulb you are looking for is a Phillips UHP 100w/120w 1.0 bulb, you can google the make and modle of the tv and you will find sites for the bulb or send details to info@soundandvisionav.co.uk
May 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Need a philips 100w bp96-00224c lamp for a samsung tv
Did you still need to find a bulb? I have one from my previous DLP TV. Just contact me: pgsponge@msn.com
Oct 26, 2008 | Televison & Video
Samsung DLP TV
No best buy doesnt carry replacement lamps. You can go to this link that I am posting and email them with the model number of your set, as they have about any lamp that you would require. heres the link.
http://servicemanuals.vstore.ca/
May 03, 2008 | Televison & Video
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
