SOURCE: IMB T40
Try this: Turn off the computer. 2. Remove the battery pack. 3. Connect the ac adapter.
NEXT:Turn off the computer. 2. Visually check each piece for damage. Replace any thing damaged . 3. Remove or disconnect all of the following devices:
a. Non-ThinkPad devices
b. Devices attached to the port replicator
c. Printer, mouse, and other external devices
d. Battery pack
e. Hard disk drive
f. External diskette drive
g. DIMM
h. CD-ROM and diskette drive in the Ultrabay
i. PC Cards
4. Turn on the computer. It should still be plugged in
5. Determine whether the problem has been solved. 6. If the problem does not recur, reconnect the removed devices one at a time until you find the failing unit. 7. If the problem remains, replace the System board .
SOURCE: ibm think pad 2635 cant do anything. please help
its the bios battrie is dead. simply replace the batt and it will work or just pull the bat set the time and it will restart then you will jsut have to do that every time you start up
SOURCE: Blinking Light
or try to remove the card. Restart it back. If your system goes fine. It indicate that the card was not properly inserted or defected.
SOURCE: Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
SOURCE: Thinkpad T40 operating system failure/won't boot
Check your RAM, reseat them, if you have RAM in both slots, swap them around. If possibe test them in another computer.
