Question about ADIC Scalar i500 Tape Drive
Inventory failed: unable to sense robotic device (202)
Trying to run robot inventory and receive error. Verified door is shut, and rebooted device and server
Ris 2d s7Hello. This is Sung ah, Jo from Asianlux Company,food service equipment in Korea. My customer korean air are using this machine.VICTORY RIS-2D-S7-GDThey told me the door doesn't work well.
Hello honorable lady. Please see these links
Victory RS-2D-S7 Parts & Manuals ' Parts Town
www.partstown.com/victory/rs-2d-s7/parts
  1. Cached
  2. Similar
Find genuine OEM Victory RS-2D-S7 replacement parts at Parts Town with the largest in-stock inventory and same day shipping until 9pm ET.
Victory 50616802 COILEVAP84E21 ' Parts Town
www.partstown.com/en-ca/victory/vt50616802
  1. Cached
Find Victory 50616802 COILEVAP84E21 replacement part at Parts Town with fast same day ... Documents for RA-2D-S7-GD: ... Documents for RS-3D-S7:.
Victory Refrigeration Parts & Manuals ' Parts Town
www.partstown.com/victory/parts
  1. Cached
  2. Similar
Parts Town has the largest in-stock inventory of genuine OEM Victory Refrigeration parts with fast same day shipping until 9pm ET. Find the part you need today.
Owners Manuals - Victory Refrigeration
www.victoryrefrigeration.com/technical-service/owners-manuals
  1. Similar
A description for this result is not available because of this site's robots.txt Learn more
VICTORY RIS 2D S7 GD Google Search
Jun 22, 2017 | Refrigerators
Tip
How to use Driver Robot to update drivers?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <a href="http://www.drivers-updates.net/"><b>Driver Robot</b></a> scans your computer and compares its results to a massive database of over one million official up-to-date drivers. Its fast, thorough scan and 100% accurate results make it our top pick for users looking for a reliable driver update scan. The drivers that Driver Robot installs on to your computer are always the latest official manufacturer drivers, putting your PC's hardware back in top form. This Article teach you <a href="http://www.drivers-updates.net/howto.html"><b>how to how to use Driver Robot to update drivers</b></a>].
Step 1: Initial system scan Right after you install Driver Robot, it spends about 2 minutes scanning and identifying your computer's hardware. It also looks at the age and accuracy of the drivers you currently have installed.
Driver Robot uses this data to compare your system to its massive driver database in order to make recommendations.
Step 2: Driver scan results After Driver Robot is finished scanning your system for missing or out-of-date drivers, it reports its findings to you.
It's here that Driver Robot makes recommendations regarding updates to your computer's drivers. Driver Robot always recommends the latest official drivers.
Step 3: Driver download and installation Driver Robot now downloads and installs the latest device drivers for your PC, directly from the manufacturer. The installation process is fast and easy.
With Driver Robot, you can always be guaranteed to receive the latest official drivers.
Driver Robot gives you the most accurate driver update scan: Our tests make our point for us: Driver Robot's massive driver database, fast scan technology, and great user interface make it the industry leader in driver scanning. It's so easy to get your computer updated with the latest drivers that we think every computer should have this software on it.
Driver Pro guarantee: Clean software At Driver Pro, we personally test and use every piece of software we recommend. We certify that Driver Robot is free of spyware, malware, viruses, and other nasty software. Try it today - you'll be amazed at the speed and accuracy of its driver scan.
Managing Driver Robot on your PC: Installing and uninstalling Driver Robot is easy and safe. Follow these detailed instructions to install the software, run it, and then remove it when you're finished.
How to download & install Driver Robot To start the automatic driver updating process, you first need to download the Driver Robot setup file from here: Driver Robot setup (executable, 5.1MB). The setup file will take 20-30 seconds to download on to your computer. When it is finished, find it on your computer and run it.
Once Driver Robot's setup program is running, you should see a screen welcoming you to the installer. Press "Next" to continue to the End User License Agreement (EULA). You have to say "Yes" to this agreement in order to proceed; press "Next" when you're ready.
As soon as you agree to the EULA, Driver Robot will begin extracting on to your system. Rest assured that this installation process is 100% reversible. The moment Driver Robot is finished installing, it will run automatically and offer to scan your system for new driver updates.
Removing Driver Robot from your PC If you no longer need Driver Robot on your computer, just uninstall it - it only takes 30 seconds. Find the folder in your "Start" menu, under "All Programs", that's called "Driver Robot". In this folder, there will be an icon labeled "Uninstall" or "Uninstall Driver Robot".
Click this icon once and the uninstallation process will begin. If prompted whether you're certain you wish to remove the software, press "Yes". When the Driver Robot uninstallation process concludes, the software will be completely removed from your computer.
on Mar 05, 2010 | Computers & Internet
IBM TS3200 tape Library error code 9E 09 Hi There
OK if you are in the UK then defiantly try going to http://tape-drive-repair.com/ for them to help as these can be a pain to seat the picker correctly and you might well need parts anyway.
However if you are in the US and are unable to do that:-
Dissconnect the power.
Gently raise and lower the picker by hand and again check for any obstructions.
Sometimes the picker comes off its rails or skips a gear.
You can also try raising the picker to the very top before lowering again - make sure the picker is totally level when it returns to the bottom.
This is the same unit (in effect) as the dell TS4000 so that might also give you another search term when googling the issue.
These units are great libraries but you must be very gentle with them when doing this sort of procedure as it is easy to bend and break things.
Also make sure the library is totally square in the Rack - i have one unit where the customer had one corner 1U too low in the rack but the library had still managed to be screwed into the rack. Because the library was no longer square, things started to jam and fail to pick tapes. Once square again all was well.
Sep 03, 2013 | Computers & Internet
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Can you give sample source code of visual foxpro program using mySql as database flatform
Create a connection: lcStringCnxRemoto = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=200.1.1.1;" + ; "PORT=3333;" + ; "UID=booking;" + ; "PWD=booking;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" lcStringCnxLocal = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=localhost;" + ; "UID=root;" + ; "PWD=clave;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal)
Accesing data:
SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal) IF lnHandle > 0 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype","cur_roomtype") IF cmd > 0 BROWSE ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2]) ENDIF USE IN cur_roomtype SQLDISCONNECT(lnHandle) ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2])
ENDIF
Creating complex sentences:
TEXT TO lcSQLcommand NOSHOW SELECT Inventory.inventoryid, Inventory.date, Inventory.roomtypeid, Inventory.sold, Roomtype.descrip, Roomtype.rooms FROM inventory Inventory INNER JOIN roomtype Roomtype ON Inventory.roomtypeid = Roomtype.roomTypeID ORDER BY Inventory.date DESC ENDTEXT cmd = SQLEXEC(lnHandle,lcSQLcommand)
Passing parameters to a query:
nValor = 12 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype where roomtypeid = ?nValor","cur_roomtype")
Calling a Stored Procedure:
SQLEXEC(lnHandle, "call myStoreProcedure(@param1)")
GOOD LUCK!
Mar 17, 2011 | Microsoft Visual FoxPro Professional...
I changed pickups in my robot, now it doesn't tune. what could the problem be?
The on-board computer that senses pitch is designed to work with the stock pickups. Changing them makes the computer unable to "hear" the pitch, and therefore unable to automatically tune itself.This is a common problem, but a Gibson authorized technician should be able to correct the problem.
Hope that helps!
Nov 13, 2010 | Gibson Robot SG Special LTD Ebony
Us robotics modem drivers 5633 win xp sp3
we are not receiving the fax and find the error "an error Occoured while receiving fax"
Jun 23, 2010 | U.S. Robotics (USR5633A) Modem
Vpn connection
That error means it was unable to connect. Can't find vpn server or security was wrong. Are you running a firewall? If so, open port 1723 and try again or shut it down while testing.
Mar 12, 2009 | U.S. Robotics (9107) Router (USR9107A)
Am trying to browse but i get this error Login
how can i enter to the facebook?
cause i cant they have blocked it
we have a firewall here on the server
Jan 19, 2009 | U.S. Robotics USR8200 (USR808200) Firewall
ADIC Scalar i500 Tape Drive Logo
1,606 people viewed this question
Top ADIC Computers & Internet Experts
David Payne
David Payne
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
