Cannotprint additional information on file from memory stick othe ketyboard action tools not fully light up
Do u have latest driver installed ofr stick need help email me drummernick2002@aol.com live help thx nick
Posted on Jun 08, 2008
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Aug 20, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony Memory Stick 8gb Pro Duo Memory card
In windows shows all files also the system files and then check your memory card and delete the files.
Or you can connect your memory card to a mac or a linux to see all files also the hidden.
Aug 08, 2012 | Sony 8gb Memory Stick Pro Duo Hg Hx 50mb/s...
How to retrieve files from a locked toshiba satellite l500 laptop
use a Live USB operating system.
You can create one very easy with this tool:
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
Choose your distro (I would go with Kubuntu), create your USB live memory stick, plug it in, boot your laptop to your new portable OS.
(make sure you select try Kubuntu and NOT install).
You will be able to browse to your files regardless of which partition they are in.
You may need additional information if you are not familiar with Ubuntu based operating systems.
I hope it helps.
Aug 07, 2012 | Toshiba Satellite L500 Series Notebook
Manual HP530 laptop Need to upgrade memory
HP Support > HP 530 Notebook PC > Main Support Page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&lang=en&cc=us
Under the bottom heading, Resources for HP 530 Notebook PC, click on Manuals.
Scroll down to the heading, Service and maintenance information.
Click on the first file listed -
HP 530 Notebook PC - Maintenance and Service Guide.
This is a Service Manual in PDF file form.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
Going back to the main support page, and again under the Resources for HP 530 Notebook PC heading, there are instructional videos available.
Repair videos and animations. (Second heading. After you click, it takes a second for the video main listings to come up)
Click on, Remove/Replace Videos
In the list on the left click on Memory Boards.
[Advice:
1) Ease the spring clip outwards from the ram memory module, ('Stick'), just far enough so the 'bump' on the spring clip, clears the Side Notch on the ram memory module.
Now ease the other spring clip outwards. When both spring clips 'bumps' are clear of the Side Notches, the ram memory module will slightly pop-up.
DO NOT bring the ram memory module to a straight up 90 degree position when removing!
You will damage the gold plated contact pins on the bottom of the ram memory module.
You will also damage the contact pins in the ram memory slot on the motherboard.
When removing and installing, the ram memory module must be angled.
2) Handle a ram memory module by the Body, refrain from touching the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic.
3) Make sure the ram memory module/s are fully seated when installing.
When the 'bumps' on the spring clips are in the Side Notches of the ram memory module, it is fully seated.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
4) At the bottom of a ram memory module is a Locating Notch.
This lines up with a Locating Lug in the bottom of the ram memory slot.
Make SURE you have these two aligned when installing.
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 17, 2011 | HP 530 Notebook PC
How to use a memory stick in my laptop Windows 7 particularly to insert the information from to stick into my compuer Windows 7
just insert the stick into the usb ..and wait for the windows to recognize it and install the device ..this will be a few seconds and it will prompt you with a balloon in the right area that will say the device is installed and ready to use..
after that it is either open an auto-play window and ask you for an action ..(you can select a preferred action and click the case to always perform that action ) and my choice will be the feature that says open the folder to view files..and if you select that case and choose this action ...every time you will insert the stick in usb port ..it will automatically open the folder to show you what it is inside..
if the autoplay is stopped..the way to find it ..is after you insert ..wait a few seconds..and look for it in My computer folder where all drives are shown ..C drive ; D drive; the cd /dvd drive and it will be there named removable storage device.
Just double click to open its folder and it will behave like any other folder ..you can copy..or cut ..or delete from it ..and also copy to it by choosing a file from computer ...right click on it ..copy ..than click on the device folder and right click infact and paste ..thats all..it behaves like moving files from a folder to another into the computer ..
Apr 29, 2010 | Lenovo 3000 N100 Notebook
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format Memory Stick Duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
When i went to erase the files on my sony 8mb memory card for my sony dsc-p31 digital camera i accidentally erased the file containing the software for the memory stick can i reformat that memory stick....
2. Format memory card
Apr 02, 2009 | Sony 8MB Memory Card 2 Pack (Red, Blue) -...
Computer turns on but now booting up
Make sure the memory stick is securely installed on the motherboard. Also make sure that any additional cards in the expansion slots are also securely installed.
I had a similar problem on another machine and it was due to a memory stick that wasn''t fully secure, I reinstalled the memory stick and made sure it was a solid connection and it resolved my problem.
Please let me know if this helps you.
Feb 03, 2009 | Dell Dimension 3100 PC Desktop
System Information
Physical memory is ur addon hardware memmory available memmory means  256 - currently usage virtual memmory = free space in ur c drive page file space is related to virtual memmory cipher strength is encryption level of your internet explorer
Nov 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
