Question about Mordaunt Short Audio Players & Recorders
Distance from wall, re mordaunt short ms 20i
Hi could you tell me the distance i should have my ms 20i's away from the wall, re the rear bass port ,
Thanks guys.
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Mordaunt Short MS5-30
Hi r_drain
great choice of speaker, always liked MS gear. They are designed to be biamped, or rather have a separate amplifier for bass and treble frequencies. You can just jumper between the terminals. They originally cam with a plate that connect the 2 black and red terminals together making effectively one black and one red. The speaker still has a crossover in line internally.
regards
robotek
Posted on Jul 05, 2008
  • 336 Answers
SOURCE: I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Posted on Feb 12, 2009
Ganx
  • 113 Answers
SOURCE: i Have a buzzing mordaunt short avant 916i cone
Hiya, its the cone. The former is touching the magnet inside. Realignment is really tricky and dont know many people who can do that so you may either have to live with it or see if someone can recone it in your area.
Best of luck
Posted on Jul 15, 2009
How do I replace the tweeter on Mordaunt Short Avant 906i speakers?
Hi - Just reading your problem with the 906's and removing the front cover to replace the tweeter. Did you ever solve the issue? because I tried today and I can't budge the silver cover once the screws have been removed. My email address is chris.clemons@btinternet.com if you can help - thanks
Feb 16, 2012 | Mordaunt Short 906 Rear Speaker
I Have a buzzing mordaunt short avant 916i cone
Best of luck
Jul 15, 2009 | Audio Players & Recorders
Mordaunt short ms409w subwoofer rear panel removal
You don't have to cut the speaker wires.
Under the foam wrapping is a connector - just unclip it!
May 17, 2009 | Audio Players & Recorders
Mordaunt short 906 tweeters
 i have found that partexpress is a good place to replace speakers and much more
Feb 24, 2009 | Mordaunt Short 906 Rear Speaker
Alesis M1 MKII bass ports
if desiring loud bass, keep port open. It is designed to be that way. If subs are in a corner, face the wall to change the wavelength and port noise wont be as evident.
Dec 23, 2008 | Alesis M1-Active MkII Main / Stereo...
Hi r_drain
regards
robotek
Jul 05, 2008 | Mordaunt Short 302 Main / Stereo Speaker
Mordaunt Short Avant 309i subwoofer set-up
Lots of ways. To set it up properly you will need a decibel meter, Radio Shack makes a nice one. With the meter volume can easily be set as well as phase. I'm assuming frequency is the crossover frequency, generally set at 80Hz. This one involves some trial and error as I am not familiar with your speakers. Don't know much about the notch filter. A good resource for setting up subs can be found at: http://www.hometheatershack.com/forums/bfd-rew-forum/index3.html
Jun 18, 2007 | Mordaunt Short 309W Subwoofer
No Power - LED not lit.
Open up the back of your gale 3080 and check the 2 fuses situated near the transformer.They look like 2 silver cylindrical shapes.Check that they have not blown if they have the will cost you around £2 to replace.Better than the 50 quid you will pay when you take it to your hi fi dealer to open up the back of it.
Aug 12, 2006 | Mordaunt Short 309W Subwoofer
182 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
chris
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
