Question about HP Pavilion dv1000 Notebook
HP dv1000 monitor just stopped working.
I can get it to work with an extenal monitor (so its probably not the video card), but the monitor is just extremely dark and won't brighten up
  • Redsoxfreak Dec 12, 2008
    I have same problem, I have to look very close then I can barely see anything, I think it's the back light, how do I replace that?
  • xyzrosezyx Jan 06, 2009
    I still don't understand where the Lid Actuator switch is located. Please help
    Scholar:
  • 53 Answers
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down HP dv1000 monitor just stopped working. - c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Posted on Jun 10, 2008
When i turn compurte on black screen only
This could be due to a couple of things. If your computer is actually starting up and you get no graphics (actually nothing at all on your monitor) then you could have a bad monitor or a bad video card. If the computer is working at all, the monitor should display something, if just an error message.
My suggestion-try an external monitor (be sure to press the Fn and special function key combo to send the signal to the external monitor).
If that doesn't work (either monitor), then the graphics card could have problems.
If the external monitor works, then you could have a loose connection to the screen or the screen could be bad or perhaps the inverter that runs the screen could be bad. In this case, you'll have to get it fixed.
Oct 23, 2011 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 screen has gone extremely dim. changed the inverter and nothing. connected to an external monitor and nothing. what is wrong? HELP PLEASE!
Two things: video card issue or video card settings. Try to go to the power options configuration of your portable system. Adjust the brightness. If changes does not take effect on your portable's display as well as the external monitor, it is a video card issue. The last option of resolution is to re-install the video driver. Click the link below and choose the exact model of your computer. Try to download the video driver for your computer. Make sure that you have the correct driver for your operating system. If re-installing the video driver still fails, unfortunately you need to have your video card replaced. Usually the video card comes embedded on the motherboard. That means you have to have your whole board replaced.
HP Pavilion Models
Jul 05, 2011 | HP Pavilion dv1000 Notebook
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
My Hp SD card reader doesn't work how can I make it work again?
Did you insert the memory card properly? because if your memory card is not inserted properly, the SD card reader may seem not to work. And if probably the problem is from the SD card reader slot, then you have to give it to an engineer for repair or better still take your laptop to Hp customer service center for repair. Thanks
Sep 24, 2009 | HP Pavilion dv1000 Notebook
Monitor screen turns off new monitor new video card had problem
If you've replaced the monitor with a new one, it's probably not a monitor problem. Try uninstalling the video card and use the motherboard's on-board video. If that's not working, check into getting a new motherboard. If it works fine, check the settings on your video card.
Jul 15, 2009 | Sony SDM-HS73P 17" LCD Monitor
NO VIDEO ON HP DV1000
lcd inverter backlight lcd screen or video card probably bad
Apr 10, 2009 | HP Pavilion dv1000 Notebook
Driver for hp dv1000
http://www.hp.com/#Support
Step 1 mark: "Download drivers and software (and firmware)"
Than follow instructions.
Dec 12, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 works fine on CRT but no LCD screen
Sounds like the LCD backlight or inverter went bad. More probably the inverter,and that's good because,of the two, it's usually cheaper and easier to replace.
Before considering those,check the lid switch to make sure that it is operating correctly and not stuck down.
Ron
Dec 10, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook PC xd card reader stopped working
Hi i am kiran, i work for HP tech support , i suggest to reinstall the Media card drivers as the link given below. Pleae let me know the status, thakyou
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30753.exe
Kiran
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Flashing Green Light on mx705 monitor
If the HP has onboard video but you have an add-on video card, remove the add-on and connect the monitor to the onboard vid. If it works you have a bad add-on video card. If it doesn't or you are already running on on-board video hook the mx705 up to a compatible HP. The older PB may be TOO old to handle it or not hve the correct drivers.
Feb 25, 2008 | HP mx705 17" CRT Monitor
HP Pavilion dv1000 Notebook Logo
2,367 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
