Question about Dishwashers
Black, oily gunk in dishwasher
I have had this problem with 2 European made dishwashers, a Bosch and an Asko (my current machine, model 3122). After 2 years the black rubber door gasket starts to dissolve, leaving a black, oily residue particularly on plastics, even plastics in the machine, such as the cutlery basket.[The rubber on some OXO utensils seems to be the same and it to gets gummy if washed in the dishwasher. Repairmen have blamed the detergent, Electasol, the same one that Bosch and Asko packed with the machines when I bought them. On the other hand, these repairmen admitted that they had not seen this problem before. Customer service said the same. Using different detergents produced only one result, dishes that needed to be hand-washed in the sink after being taken out of the dishwasher. The rubber gaskets continue to deteriorate, including the new gasket put into my Asko about a year ago. Questions: What is causing this? How can I stop it? Is the gunk a health hazard?
  • Anonymous Apr 21, 2009
    I have a Whirlpool Dishwasher. The Gasket started falling apart after the first year. If you touch the gasket, you get the black coating on you. I have used only Cascade in it. It is painted steel and not stainless steel.
5 Suggested Answers
SOURCE: Dishwasher leaves a fine black sludge
I work in a hospital and have seen this problem with our scope washers (a very sophisticated dishwasher with lots of safety features) and it turned out to be a faulty pump motor.  Some pumps have black ceramic magnet in them and if it cracks it will breakdown and mix in with wash water creating a black smudge on everything with bits. Just as you described.  Unfortunately, I have never taken a part a dishwasher motor so I don't know if it's the same type of motor.
Posted on Oct 11, 2007
SOURCE: Tablet not fully dissolving during
How do I remove the filter on a CONCEPT II dishwasher? It is full with stuff.
Posted on Mar 30, 2008
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
BurntLime
  • 8 Answers
SOURCE: Not cleaning properly
You could be using the dishwasher at a higher temperature than the biological agents in the tablets can handle, and so become denatured and can't clean your dishes properly. I have had this problem a little while ago and found that using the "eco" setting (should heat the water to around 30c and has the added bonus of using less water) works well and makes sure that all of the dishes are clean.
It could also be a problem with the release system, where the door the holds the tablet can't release it on time and so the tablet does not dissove. Have a check to see if anything is stopping the door opening and see if there is anything you can do to make it release on time.
Hope this helps,
BurntLime
Posted on Jan 05, 2009
  • 677 Answers
SOURCE: dishwasher does not clean dishes and leaves spots on everything!!
The problem is hard water that is leaving the spots. There is a fantastic product out called the dishasher filtration system. It filters the water going into your dishwasher and works amazing. It is very affordable and very easy to install. You can get it at www.dishwasherfilter.com.
Posted on Mar 14, 2009
How often do i refill rinse aid in dishwasher?
It is my understanding the Technik dishwasher is serviced as a whirlpool or bosch dishwasher. Therefore the dispenser unit is same as those used in sme of the European dishwashers. The Whirlpool model WHIRLPOOL ADG4952M would be close to it. Is yours something like this.
Apr 21, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
Where can I get Bosch Dishwasher SRS43E22EU model user manual (English) ?
Hi
The essential problem with your request is that your dishwasher is a European model rather than British. Therefore, the user manual for this washer is published in most European languages - expect for English:
I have identified the the British version of this dishwasher, but there may be some minor details which differ from the European version. You can download the instructions for that model by clicking on the following link:
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ujqlsOicdcso0pdmdb---Gak&UMOBID=ujqlsNecdcso0pdmdb---Gak
After clicking on the link a "File Download" box will appear. Choose "Save" and save the file to your PC for future reference. Alternatively, you can "Open" the file and print it from Acrobat. If you are unable to open the file, you will also need to download the latest version of Adobe Reader:
http://get.adobe.com/uk/reader/
If you are unable to download the manual or if it doesn't relate to your machine, please post back and I will arrange an alternative download method for the manual or find a more suitable manual:
Regards,
BElectric
Nov 29, 2010 | Bosch Dishwasher Glass Rack Insert...
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
Lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
Jan 25, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
My asko 3122 dishwasher never heats up
Sounds as though the element burned out I would suggest you have a qualified technition out to confirm and replace so he\she can inspect the machine and see if there is indeed another fualt,the element can blow for a number of reasons but like a light bulb blowing it is electrical and can go at any time,I would not suggest you attempt the repair by yourself unless you have some sort of experiance with this type of thing.
Jan 23, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Model SHU4006C Dishwasher
I just bought a Bosch made for Sears and I'm trying to return it. I'm going to get a Kitchaid instead. We got ours two months ago and Sears is being difficult in letting us return it. I had a technician come to the house and he said it smells--slightly oily or rubbery. I went to a store and all of the Bosch dishwashers smell. Anyone reading this, don't get the Bosch.
Jan 03, 2008 | Dishwashers
Dishwashers Logo
436 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
