Question about Symbol Spark LS 1004
Driver for symbol scanner LS1004
I am looking to download a driver for symbol scanner LS 1004
  • Anonymous Nov 25, 2008
    I also need the driver for this scanner
    Problem Solver:
  • 13 Answers
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Posted on Sep 09, 2008
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
I need to know the firing order for a 1992 oldsmobile cutlas supreme. I need to know what spark plug wire goes in what order on the cyclinders
1992 Oldsmobile Cutlass Supreme FWD 3.1 liter DOHC V-6 VIN "T"
1992 Oldsmobile Cutlass Supreme FWD 3.4 liter DOHC V-6 VIN "X"
Hope help with this (remember rated this).
May 31, 2010 | Symbol Spark LS 1004
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Set up for Symbol LS5000
Hello Fenandez,
there is no driver needed. Just select the programming barcode for the interface (RS232, Synapse,Wand) you want to use on your host device. You would need just the Reference Guide with the barcodes.
Aug 19, 2008 | Symbol LS 5000 Barcode Scanner
LS 1004 Barcode Scanner
Mar 14, 2008 | Symbol Spark LS 1004
LS 1004 Symbol Barcode Scanner
The host type are the Interafces which are supported by the scanner directly (no adapter needed). And the Synapse adapter can even an old scanner connect to new interfaces like USB.
As you state you have the adapter for keyboard wedge. You would just need to download the Reference Guide for the "Synapse Smart Cable" at a configure it acccording to your connection parameters.
Mar 13, 2008 | Symbol Spark LS 1004
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Oct 18, 2007 | Symbol Spark LS 1004
Symbol Spark LS 1004 Logo
1,152 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
