Question about D-Link AirPlus DI-524 Wireless Router
Dlink not working on my computer that receives signal
My daughter reformatted one of our computers. I have installed the drivers and can see dlink in the connections. It shows dlink under network connections and says that it is unavailable. I can't figure out how to fix this. Help!
  • 2 more comments
  • Anonymous Jun 10, 2008
    DI 524
  • confused34 Jun 11, 2008
    Thank you for your suggestion. I did get it working. I tried to delete the problem, but I could not find a way to do that. On the computer receiving the wireless connection- when you click on the computers in the bottom right corner it gave you ways to connect. I had chosen belkin and something else, but when it was changed to default it then worked. I had also unplugged the router and reset prior to that so it may be what made it work. Sorry I don't know this technical stuff.
  • SIGA_AKO Jun 17, 2008
    my pc which is connected via cable is working. but connecting via wi-fi it says no connection found. this thing happened after re-formating my pc. please help me with this. thanks a lot
  • Michael  Yamakawa
    Michael Yamakawa May 11, 2010
    Is this wired or wireless? If wireless, are you sure there isn't any WEP or WPA security enabled?
    Also, you may want to reset it by unplugging the router, waiting 20 seconds and plugging it back in
  • 550 Answers
Visible & unavailable means that the wireless security settings are not the same on the recently formatted computer, as on the rest of the network.
Open the wireless configuration for any computer that can connect to the network and copy the security settings (wep or higher) to the unconnecting pc
connect to the router by cable from the non-connecting pc, use the web interface at to read the security settings, and copy the settings to the unconnecting pc
then it will connect
Posted on Jul 11, 2008
Dlink DIR-600. I'm in an apartment where we're all connected to the internet through a router in another apartment (i.e., there's another router between the Dlink & the Internet). In...
It is pretty strange that only one PC is not able to find and connect to the network. All I can do is give you a few suggestions to check the Network and the PC Settings.
-The SSID Broadcast and DHCP Server should be ON from the router, so that the network/ router would be visible to all the nearby machines and could assign IP automatically.
- Try to move the PC closer to the router and see if it can find the signal (the PC wi-fi card may not be power enough to receive the signals)
- Make sure that there are no obstacles such as concrete walls, metal cabinets between the router and PC. This reduces the signals and the PC fails to recognize them. Based on my on-site experience, I suggest that you may relocate the router to another location depending upon your network environment. It has always helped me a great deal. Placing the router at the desk level, avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
- Change the LAN settings of the PC to defaults.
Hope it helps! Good Luck! Thanks for using Fixya!
Sep 09, 2011 | D-Link DIR-600 Router
click on this link and look up the revision that matches your dlink modem card .
go to control panel and click on system to figure which operating system you have .
Jan 25, 2018 | D-Link DFM 562IS (DFM-562IS) Modem
Had to reformat the harddrive, installed windows XP pro and am not receiving a signal to monitor. Do I need to re-istall a monitor driver
Usually reformatting would include the drivers for the monitor. Do you have a graphic card in this PC?
Jun 07, 2009 | HP L1906 19" LCD Monitor
Can't load wua 2340 driver
Here is the correct driver install package, download the zip file to your desktop, then double click the zip file to get to the setup.exe file for the dlink adapter, first it may ask you if you want to remove the driver and all its components, say yes, go ahead remove all previous dlink drivers. Then, after the driver is gone(look in your program list to make sure its gone), doubleclick the exe file again to install the driver correctly, insert your usb adapter when prompted to. You are better off using this dlink adapter with an external base with a usb extension cable so you can mount in by your window(to catch the networks)
I am using it right now (wua-2340), it comes in low, but with a fast download speed even fast enough to stream video or audio.
click on link below(if you can't, copy and paste the link into your IE or furefox, hit enter
the driver date for vista and win xp is from 2008-
Feb 09, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
Want to use wireless without running cables
Did you load the DLink software onto your computer?If so you have to configure the DLink control Panel to recognize the Internal wireless card in the computer.You may also need to take the wireless card out and restart your computer,then shut it back down and reinstall the card so the computer can recognize the card and reinstall the drivers.If it cant find suitable drivers it wont install.While you have the card out look at the brand and version number and try to download software to desktop to install in case windows cant find any.If you have a cat5 (ethernet) cable you can go hard wired till you get the wireless working.
Apr 22, 2008 | Computers & Internet
We may download the drivers from DLink's support web site. You will also find the installation instructions there.
Apr 16, 2008 | Computers & Internet
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Hi :)
You have to check correct fitment, if ok. Check the Lan card is disabled in device manager. check for driver and uninstall the driver first and install latest from manufactuers site.
Apr 12, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
516 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
