Question about Goldstar DH504EL Dehumidifier
My 2 year old dehumidifier does not remove adequate moisture as before
  • 828 Answers
How much moisture a dehumidifier can remove from the air is directly related to temperature and dew point. Check the relative humidity in the space where it is located.
Posted on Jun 06, 2008
Our dehumidifier is about 2 years old. It turns on and sounds fine, but it no longer condenses any moisture from the air. Does the refridgerant need rechargeing?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 13, 2011 | LG LHD45EL Dehumidifier
It is not taking moisture out of the air. The tank is bone dry, yet the controls indicate it is in moisture removal mode, the fan is running and the temp gauge shows 60% rh. Also we suspect it is drawing...
heatman101
Jun 28, 2011 | DeLonghi DE500 Dehumidifier
My dehumidifier is two years old and only used during the summer months. This season it is running but not removing moisture from the air...the collection bucket is completely dry. Help!
heatman101
Jun 06, 2011 | Haier 45-Pint Dehumidifier
The dehumidifier isn't taking the moisture out of the air.
is the compressor in the unit hot to the touch,or are the coils freezing and thawing when it runs<if so you probably need to add some R-134a refrigerant,these type of units are notorious for losing all or part of their refrigerant charge,but unless you have the equipment to remove old refrigerant and vacuum the system down and recharge it it can get costly
Apr 15, 2010 | LG LHD45EL Dehumidifier
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
Humidifier measuring wrong %
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Aug 03, 2008 | LG LD65EL Dehumidifier
Friedrich dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Goldstar DH504EL Dehumidifier Logo
123 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
