Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba 2860 stapler problem
How do you disconnect the stapler on a Toshiba 2860. It is always jamming and we don't use it that much. But it will shut down the whole machine.
Chris Coughlin
Level 2:
  • Expert 1,326 Answers
  • Posted on Jun 06, 2008
Chris Coughlin
Expert
Level 2:
Answers
1326
Questions
Helped
441366
Points
872
Try not loading it with staples... See what happens, just don't use that funcation.. That copier is old and parts are going to be hard to find.. Gan you live with out the finsher? If so dissconnect it and make a exit try..
How do I unjam my bostich T6-8 stapler and my old model T5-8 tacker?
How to Unjam a Bostitch Stapler
  1. Disconnect the construction stapler from the air supply. Use a hammer and punch to do this. ...
  2. Push the driver upwards and past the jammed staple. Do this by putting the punch at the tip of the driver, which you should see coming out of the nose. ...
  3. Tap the hammer against the punch and the jam should clear.
https://homeguides.sfgate.com/how-to-unjam-a-bostitch-stapler-13401638.html
How to take apart model 131 acco heavy duty stapler
Turn the stapler upside down and shake it to see if you can remove any of the staples. Attempt to open the top part of the stapler. If you can, remove the existing staples from the magazine. Then, unravel one end of a paperclip and attempt to remove the jammed staple from the head of the stapler.
https://smallbusiness.chron.com/open-stapler-jammed-shut-49396.html
1helpful
How do I make the Optima 20 electic stapler model 48208 work after putting in the staples. I put the paper in as usual and it does not work. I have put the staples in correctly as I normally do, but
Unplug it, take it apart and examine the switch actuator and switch to see why they don't trigger the stapler. There's a good chance you'll find the actuator is broken or jammed by a foreign object, or the switch is worn out. Metal-filled epoxy works well for repairing ABS plastic parts.
Another possibility is a broken power cord. You can test the electrical parts for continuity with an ohmmeter (unplugged, of course!).
Pls. send a catalog of toshiba copier 2860
Hallow, in order for you to download catalog or brochure, please click here and specify toshiba copier and then select 2060/2860.Here you can download the manual or brochure and save on a desktop or any other location you so desire. Happy new year.
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
What is the re sale value of a Toshiba 2860 Copier?
2860 is out of order it cost about 200 dolars.
2helpful
Can you produce me a copy of toshiba 2860 service manual?
Copier service manuals can be purchased from www.justmanuals.com.They are a pay site but seem to be reasonable.Good Luck
Toshiba 2860 copier, paper does complete the transfer process.
Did you get the drum shaft reinstalled and latched? If not, the drum won't rotate correctly which will cause poor transfer (smudged image) and jamming.
Stapler
please make sure that there are no staples jammed in the unit,
take the staple cartridge out, release the leaver on the staple cartridge and remove the first sheet of staples, close up the leaver, and reinsert in the copier.
then try to staple again
k24674
ADMIN Andrew
ADMIN Andrew
