Ar-5132 sharp copier
I have just changed the developer and the toner in my ar-5132 sharp copier and now when turn on the machine I get an error code h-3
  • jimbo111 Aug 30, 2008
    thanks that corrected the problem. Jim R
  • 146 Answers
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Posted on Jun 06, 2008
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
232 people viewed this question
k24674
jasbo
jasbo
