Question about Panasonic Televison & Video
Panasonic DMR-EZ37VK unit is connected to basic cable and will record by pressing the record button, but scheduled timer events do not record [VHS].
Make sure that you have the unit in vcr mode rather than dvd. this worked for me.
Posted on Feb 12, 2009
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
Cannot download TV Guide schedule-Verizon FIOS
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
Sep 15, 2008 | Panasonic DMR-E85H DVD Recorder
I have the DVD/VHS recorder/player Panasonic Model DMR-E75V, I have connected the 2 scart cables to the digital decoder and TV set but I cannot record even if I can play the VHSs and DVDs normally. It's a...
First of all you have to connect only one SCART cable ( one end to TV and the other to DMR ).When you are watching a program on TV select the DMR source ( input selector ) to SCART. Just press the record button with a blank DVD inside and it will record. Some Digital broadcast might have copy protect content which will prevent the recording from happening.
Mar 10, 2011 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Timer Recording
To schedule a weekly or Mon-Fri program on the DVD scroll back in the "date" box (instead of forward to a future date. You will have options for once a week or Mon-Fri.
Jul 27, 2008 | Panasonic DMR-E75V DVD Player/VCR
Panasonic dmr-ea38v vertical static
I would start by checking which scart leads are in which connections and check which av channel you have the player on.
e.g. AV1 connected to the TV, AV2 connected to the decoder.
Then the DVD player viewing/recording channel should be on AV2 not AV1. Does he have any high powered/frequency devices close by?
Jun 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Cannot Record using VHS
The question here would be one of two things. Obviously without probing further it would seem you're having an "unusual scheduled recording" issue. But, without further information it's difficult to tell.
For one, are you recording from straight signal (cable or antenna into the RF IN of the unit), or are you recording from a box (cable or satellite receiver or D/A converter, etc)?
Do your scheduled recordings record the first and not even pick-up the second, or do they record but only record static?
These are questions that will need to be answered before further assistance can be provided.
Feb 20, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Nothing records when I do a scheduled recording
Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok
Check Q008 for dry joints
Nov 24, 2007 | Panasonic DMR-EZ37VS
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
